Decreasing Down Pressure 3 Point
91diesel
BX23S Homemade hyd toplink/sidelink, AgriEase Snowblower
Dec 31, 2021
64
25
Fairbanks, AK
...... Here I am in -30*f Fairbanks, Alaska trying to picture a 'soft' snow covered driveway :LOL: . That is something that just doesn't happen here!
10,678
I've seen pull behind blowers that use large lawn mower tires with hydraulic lift cylinders to adjust the height and allow them to float over soft ground.
fikey
15
Naples, Idaho
That is probably the road I am going to take (similar). I have two gauge wheels I mounted to the back. I think a couple of heavy duty compression springs and shims, will allow me to do the same thing.
91diesel
Dec 31, 2021
64
25
Fairbanks, AK
In the meantime, I'd adjust your toplink. Even up here with pretty frozen ground, the difference in bite angle (driving backwards with a 3pt Hitch blower) makes a big difference if it 'digs' down towards and sometimes into the driveway surface, or 'floats' up on the snow a little. Most of the time I'm trying to get my little baby one to dig more, but when I'm 'widening' out driveway entrances and the edge is soft dirt and rocks under the snow I retract the top link to raise the bite edge of the blower and it has a tendency to leave more snow and float up. I'd think lengthening your top link would lift the forward edge and create the same effect. But......heavier blowers and 'soft' snow covered ground isn't something I've dealt with. My blower is probably in the neighborhood of 480lbs. However the snow surface is 'soft' and it will definitely float much more with the bite edge of the blower tilted up.
Dustball
2016 B2650HSDC
Sep 15, 2023
510
377
Hudson, WI
I'm sure someone can fab up gauge wheels attached to gas charged struts or pneumatic cylinders. Simply pressurize the struts/cylinders just enough to lighten the load and you'll still have a bit of float action.
Could probably use dock wheels if you want them to be able to skid laterally during cornering.
fikey
15
Naples, Idaho
I like the idea. I am trying to decide whether wheels or a "shoe" would be better. I can make an argument for either. Any thoughts?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,186
2,846
Near Lancaster, PA, USA
As long as you don't turn much, either may work without mods. For turning you're better off with wheels that swivel or skis with sides curved up.
One of the snow plows I used had skid plates that looked much like disks. The "bowl" shape rode up over stuff in any direction without needing to rotate.
fikey
15
Naples, Idaho
Where can you find those cylinders? Having a hard time finding.
Dustball
2016 B2650HSDC
Sep 15, 2023
510
377
Hudson, WI
Surplus Center is one place. A double acting cylinder would work , just need a filter on the upper port.
You could use air shocks for vehicles mounted upside down. Random example-
10,678
7,303
5,255
1,055
If the link works, there's some technical drawings and photos provided by member @Dave_eng in 2021. Uses guide wheels with hydraulic cylinders.
His parts start at Post #14 and after. Very nice design.
Inverted Snowblower ..Yes or No | OrangeTractorTalks - Everything Kubota
I'd probably still try making the top link a little longer first just to try it.
Nothing ventured nothing gained.
The aspect which has shown to be very important is the width of the wheels on the blower because of the weight they carry.
Using adjustable trailer jacks does not work because the wheels they come with are too narrow.
10,678
All of this is going to be a moot point till next year as we have gotten cold enough to freeze the ground solid.
I can say this because the OP is 5 miles north of me.
6,240
still curious what tractor he has, sounds like it doesn't have 'draft control'. That would keep the blower,say 2" off the ground.....no need for 'training wheels'.
