I’m in the “never will come loose with a wrench now“ camp.
You may be able to grind it flat with corners but that is a lot of work, then use a smaller size wrench or socket.
There may be some tool that you can find that works by grabbing the inside of the hose fitting. Something like an “easy out” .
Good luck with it.
You might be better off getting it off the tractor and getting a machine shop to get the fitting out of the block.
Good luck with it.
