L3901 won’t start, clicks once
OXX
L3901
Nov 16, 2024
Mississippi
L 3901 has been down for a couple months. I just haven’t had time to get to it. It was last used mowing and started struggling while driving it. Made it to a safe enough spot to park it. Since then, it will not attempt to crank. Dashboard comes on, glow plug buzzes, but when turning the key, I get a single click. Nothing more. Have wiggle tested all of the normal safety switches, but have not yet taken anything apart or done any multimeter testing. Suggestions on most likely culprit? Thanks.
Vlach7
L47 305DT JD500C
Dec 16, 2021
452
329
Frazier Park Ca
History of struggling, did it overheat? How are the fluid levels, how do they look? Are you on top of maintenance? Can you charge and load test your battery? How many hours and any significant history?
7,223
First thing to check on a no crank problem is always battery.
6,285
top three causes...
bad battery, remove properly recharge or replace
bad primary battery cables, ANY corrosion, replace with new ones
bad starter solenoid, bypass to test/confirm/deny.
