Help with Kubota L3608
Xoce
Europe
Nepali hooker fucks tourist in hotel room, takes cum on face then asks for tip in hindi. Punjabi bhabhi cheats with nephew while husband watches cricket, takes creampie on kitchen counter. Srilankan teen loses virginity to mallu boyfriend, films every second. Bangladeshi wife swaps husbands with friend for night, takes double penetration while filming. Marathi girl squirts on webcam, tamil aunty teaches young boy how to lick pussy. All fresh uploads daily, no paywalls, just desi smut.
Mumbai bhabhi films herself fucking delivery boy while husband works night shift, takes facial then sends clip to lover. Pakistani chick in burka flashes tits in public then fucks stranger in alley. Telugu college couple skip class for outdoor quickie, mallu aunty rides young stud while husband sleeps. Tamil girl takes bollywood style cumshot on tongue, nepali teen experiments with anal for first time. Every video real homemade, all free to stream or download.
JimmyJazz
1,273
805
Pittsburgh, Pa
Maybe the dealer will help you out given the circumstances. It sounds like there might be an obstruction in the fuel line. Try removing the line at the filter and make sure the fuel is flowing freely into a receptacle of your choosing. If its not attempt to clear the line by blowing compressed air into the line from that location. This happened to me and I blew into the line with my mouth. A leaf fragment had somehow found its way into the line. It appeared floating in the tank. Good luck.
10,675
My Kubota starts perfectly.
The engine runs smoothly when idling, exhaust fumes are OK.
The hydraulics work both at the front and the rear.
When I accelerate, it works fine for about 6-10 seconds, then you can hear the engine starting to slow down, it starts to misfire and the speed drops significantly.
At this point, it also starts to smoke and stutter.
It no longer responds to the accelerator - so pressing the throttle to full has no effect.
Reminds me a bit of a "banana in the exhaust", i.e. a blocked exhaust.
Let the engine idle, wait a moment and I can rev it up again to 2,000 rpm, for example, which it holds for 6-10 seconds.
Then the whole thing starts again.
What could it be?
What could I check?
Today I bled it several times - that improved the symptoms a little, so that it at least holds the 2,000 for the 6-10 seconds mentioned, but it didn't get rid of it.
The exhaust pipes are clear from the engine through the manifold to the end (I had initially suspected a bird's nest in the exhaust).
The air filter is clean and clear.
The tank is full.
The diesel filter is new.
The fuel tap (with filter) is new (water separator?)
History of the tractor:
I got it from a dealer who buys used tractors, dismantles them and rebuilds them.
Completely repainted and replaces consumables.
It is possible that it had been standing there for a long time.
I had the tractor delivered - the tank was of course pretty empty.
So I filled it up. Then I drove the tractor (about 3 kilometers) and used the mulcher to mulch an area of grass of about 1,000 square meters. That worked great.
Then the tractor stood still for 4 days.
Today the problems mentioned occurred, after about 200 meters of driving.
Algae / Bacterial in the fuel is the most likely.
Get fuel treatment first.
