B2910 bogging engine
Doug57
Kubota B2910
Nov 10, 2024
Dayton, Ohio
I have a Kubota b2910 that runs good for about 10 minutes then engine looses power down to a stall. This just started a week ago. I replaced fuel filter and air filter, didn’t help. Tractor has 1100 hours on it, always garaged when not using. I’m not sure what my next step should be.
Thanks
Doug
Oleracer
B2150 Kubota LA 350 750 Woods S250 Bobcat 300x deere
Jul 18, 2024
243
280
CT
Drain some fuel in a glass bottle. Let it settle. Water maybe?
BAP
Dec 31, 2012
3,097
1,234
Check fuel line from tank to filter. Make sure the fitting into the filter assembly is clean, notorious place for collecting crap and reducing fuel flow
Oleracer
Jul 18, 2024
243
280
CT
I did drain fuel into jar, I did not see any water separation. The fuel has a greenish tint to it. Maybe I got a bad tank of fuel?
You very well could have. Its fuel correct? Doesn’t smell like gasoline?
Cheap enough to drain and dump 2 gallon of fresh. Look to see color when you put it in can.
10,187
Good diesel is a greenish tint if it's not offroad.
