Lets talk DRO's my friends!
2,775
I have been looking around a little and I have decided to add a DRO to the new "hobby lathe".
I found a SINO 2 axis on Aliexpress for about 80-150 bucks.
However I was thinking about getting a 3 axis and adapting the 3rd axis to the tailstock somehow.
The cost difference between the two and three axis is less than I spent at the bar last night, so ??????
Anyone tried this?
Pros????
Cons????
Got a line on a better brand for similar dough?
5,203
1,888
I've been wanting to do it too, on my old Craftsman 12x36 (atlas 3996 I believe). Just haven't been able to pull the trigger yet. Quite a few FB groups for us hobby machinests and there is some good information out there.
On this old craftsman it doesn't have a carriage stop so when I'm turning and get close to the end, nothing stopping it and no way to know where to stop. Same for the crossfeed, I have been using the dial on the knob to set depth but my eyes are not what they used to be. I can get .004 close (and usually that's good enough for what I do) but I'm picky. I want it .0002 and that's not happening with the crossfeed dial. I don't do a "lot" of really precision work but every once in a while the need is there and if I miss it by much, it usually ruins the part.
watching this, I want to know as well.
Mark_BX25D
Bx25D
Jul 19, 2020
1,747
1,263
DRO?
To me, that means, "Dining Room Orderly", but never spelled out that way. It was always shouted by a Drill Sergeant, and if you were the DRO on duty, that meant you were going to get messed with. Especially if it was Drill Sergeant Williams.
But I kinda think you might be talking about something else! :ROFLMAO:
Dustball
2016 B2650HSDC
Sep 15, 2023
286
166
Hudson, WI
DRO?
Digital Read Out.
Gives you a display of axis positions on a mill or lathe rather than trying to read the dials on the hand wheels.
6,334
DRO?
DRO = Digital Read Out
Edit Dustball typed faster than I did!
lynnmor
B2601-1
May 3, 2021
1,444
1,159
Red Lion
Search for micrometer carriage stop, there are numerous ones available.
Yooper
3901 LA525
May 31, 2015
1,527
529
NE Wisconsin
I made an individual dro for my tailstock on the Enco to do some precision drilling and reaming. Worked great! Can’t remember the reason I took it off but it hasn’t been on since. If you do go this route I would suggest making the mounts for the scale easily removable. Looked to see if I had a picture of mine but sorry, don’t have one.
Old Machinist
May 27, 2024
106
111
NE FL
Never had one or seen the need on a lathe. They are a must have on a milling machine.
2,775
I was thinking about doing that with a Chi-Com caliper set.
I was just thinking that it might be nice/look better to have it all in one set up.
Still "kicking it around'.
I am going to "seriously" look online today for one.
Hahaha...Your "handle" certainly suggests that you are much better trained than I am, but I'll take all the help I can get.
I will probably order one for my Chi-Com mill when I place this next order, and do them both at the same time. (y)
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
135
75
Indiana
I put one of these DRO PROs ones on my lathe. It is a 'cheap' Chinese model, but has been fine for the 5 or 6 years it's been installed.
Your installation is what really matters. Properly done, these really aren't just a 'bolt-on' item. I needed to fab brackets and shields. I wanted the scales mounted securely, protected from chips and (for the carriage one) mounted in a way that didn't impinge on the travel at all. And I wanted the display mounted 'just so', requiring me to fab an arm and mount for it as well.
Putting a scale on the tailstock seems like WAY more bother than it'd be worth. If I need to drill to a precise depth, I'd just put a chuck on the toolpost and use the carriage...
My mill has an old Sony DRO - super nice, and it's been perfectly reliable for 15 yrs or more. It also has mag scales. I wanted a matching model for the lathe, but couldn't find one at a price I could justify...
