I hope I posted my pictures correctly. I have a 40 year old B7100 and it is leaking from the bottom of the front gearcase just above the front axle frame. I could not see where it was leaking until I removed the front axle assembly. There is an aluminum plug in the bottom face of the gearbox cover and it drips about a half an ounce of engine oil when the tractor is shut off. I ordered a new plug from my dealer and he said just pull the leaking plug and tap in the new plug, no sealant required on the plug.
As I would rather not replace the plug again I was wondering if anyone has had this problem and solved it by drilling and tapping for a pipe plug. Thanks, Larry.
