FEL losing hydraulics somewhere
kjrobinson
L345DT
Sep 9, 2024
17
Runnells Iowa
I have a 345DT with a L1720 loader, if I raise the loader and shut the tractor down, after a few hours the loader has dropped all the way back to the ground. I have checked all connections and don't see any leaks, where should I look at next. Thanks for the help, everyone.
Workerbee
Zd21
Mar 1, 2020
356
222
MN
Most often its a valve leaking internally. If your tractor has a joystick, check that out.
6,934
Thanks Dan, more than likely it would be the valve, I was planning on switching over to a joystick and getting rid of the original 2 stick valve anyway.
If its not leaking externally nothing else it can be. A new joystick valve will leak as well - just a matter of how fast.
