Auxiliary Hydraulics
kjrobinson
L345DT
Sep 9, 2024
17
Runnells Iowa
I removed an auxiliary hydraulic from my tractor, the pictures shows where it was hooked up at. I attempted to plug these 2 connections but when starting up the tractor it starts to whine, should I have connected in a recirculation line where I took off the auxiliary lines?
5,672
You cannot plug those ports - it deadheads the hydraulic system They have to be looped together.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
679
289
Herald Calif.
I have some of the original caps that were on your tractor. You remove the four bolts and take off the aluminum block and mount the cap on and it will circulate the oil. If you need one send me a message.
kjrobinson
L345DT
Sep 9, 2024
17
Runnells Iowa
That sounds better than having to make another hose, can you text or call me @ 515-808-1232
