L3800 4wd with Ag tires - Camber and toe in
rwthomasjr
L3800
Jul 8, 2012
Columbia, SC USA
What is the proper toe in and camber for my L3800 HST-4wd Kubota with Ag (11.2-24 front and 7-16 rear)tires. I believe my unit was cambered for 2WD. Is it ok to run the front wheels straight up ( no camber and little to no toe in)...?
Benhameen
2012 Kubota L3800 HST W/FEL and 1963 JD 2010 row crop utility
Jan 27, 2013
713
135
Southern IL.
I believe that info is in the manual.
I'll post a pic of it, once I get out to the garage.
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
I don't think you can adjust camber on a 4x4 tractor.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
I didn't think you could adjust the caster and camber on a tractor period. I figure it was a straight solid axle designed to take weight. Its not like tractors travel at a high rate of speed and hit nasty potholes on the interstate and need to be adjusted.
WFM
L3800
Apr 5, 2013
1,528
979
Porter Maine
I noticed the front tires on my L3800 this afternoon as my son was driving it, the top of the tires lean in towards the engine 3-6" compared to the bottom of the tire. Or at least it looks like a lot. It does this for what reason ?
Bluegill
Jan 11, 2012
1,559
Success Missouri
The top of the tire should lean out away from the tractor. In at the bottom, out at the top. Positive camber, this is built into the front axle, no adjustment. I believe you were seeing a tropical delusion. ;)
LeadHead
Kubota L275, Allis Chalmers WD45, King Kutter II 3-point tiller, dirt scoop, brush hog, back blade
Sep 29, 2009
86
Illinois
Am I the only one here who would love to see pictures of his tractor since he says it has 11.2x24's on the front and 7x16's on the rear? :D
Bluegill
Jan 11, 2012
1,559
Success Missouri
Yes, good catch. I'd like to see that! :D
But he looks to be a 'Hit an Run' with just the single post... :confused:
