L2501 64 in bucket
Firedog
Kubota L2501
Oct 23, 2024
26
17
McKeesport
I have a row of holes on the front of the 64 inch bucket. They look factory drilled and spaced. I’m not sure if I should pick up a toothed blade to protect the front of the bucket. I have zero experience, except the 4 hours of seat time. Not including the online research that has me confused. I’d like to protect the bucket if possible and I will be moving piles of fill, that includes chunks of asphalt, concrete, stone. Then grading it the best I can. I see a few toothed blades online and was wondering if all the holes would match on the aftermarket ones or should I visit my local dealer for one.
4,012
2,477
You can probably get a reversible bolt-on edge from you dealer, just need the bucket part number. Or, get a straight, toothed or serrated edge aftermarket. You'll need to measure the length (add maybe a little to protect the bucket corners), hole spacing, and hole size. It'll be a special order.
I reversed mine and it's starting to show a little wear near the ends already. I haven't used it very much, and that's all dirt, no rock, so I definitely recommend one.
Yotekiller
Sep 29, 2023
459
579
Southern Indiana
I have the Kubota factory HD bar on my bucket and it's worked well. These are also a popular option...
Firedog
Kubota L2501
Oct 23, 2024
26
17
McKeesport
Much a
much appreciated. Thank you
6,881
I have the Piranha. Increases performance digging and cutting through roots in addition to protecting the factory edge. I haven’t beat on a lot of large rocks or chunks of concrete with it so can’t say how it would hold up to that. I know it’s good with potato size rocks. Took less than 30 minutes to install.
Firedog
Kubota L2501
Oct 23, 2024
26
17
McKeesport
Thanks, I appreciate the feedback
Thank you for the advice. So it just slips over the front edge and bolts on the sides of the bucket ?
6,881
Exactly. The side of the bucket isn’t very hard to drill.
5,577
I made this one. It was relatively easy/fun to make.
Honestly, I only made it cause I thought it looked cool... :giggle:
Recently I was digging a pile of dirt with the regular blade when it dawned on me that I had made this thing, and it was just sitting there in the barn.
So I put it on and WOW...it made a huge difference.
It slips over the edge and is bolted onto the sides as well.
