Front PTO option for a B2150
300zx
1979 B7100D, 2009 ZG20, 1991 B2150, 1990 B6200
Dec 1, 2010
445
Forest, VA
I have a B748 snow caster/blower left over from my B7100. It uses a front PTO. I see where Kubota has an optional front PTO kit for the B2150, so I was thinking I might adapt the blower to my newest tractor. Has anyone used it and does it have the small 17 spline connection or the bigger set of splines? Does anyone have one they would part with?
John in VA
300zx
Dec 1, 2010
445
Forest, VA
No, I mean front. It bolts to the fan pulley on the front end of the crank.
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
As far as I know all the B7100 front PTOs have male splines on the crankshaft/pulley. The picture you posted shows female splines on the pulley. I think you would need to make or alter a shaft to engage the female splines.
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
375
10
Homer City, Pa.
John, would you not just remove item 10 and you're in business?
It would expose the end of the crank just like the 7100.
Big Kahuna
300zx
Dec 1, 2010
445
Forest, VA
You are right. I hadn't come to that realization yet!! I do have the male spline adapter for the B7100 that was used to bolt on to the front pulley if the splines on the end of the crankshaft were damaged. I had forgotten I had it. I could probably adapt it. It has 3 holes rather than two.
John in VA
300zx
Dec 1, 2010
445
Forest, VA
Big Kahuna
No. The B2150 crankshaft doesn't have any splines on the end, if understand what you are saying.
John
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
If you have or an get part #10 in good shape. Then it would be relitivly easy for a machine shop to make the corresponding shaft with the male spline. It is easier to cut male splines than female splines. Or if you can buy the shaft with the correct male splines you could have your old shaft from the snowcaster welded to the new shaft with the correct male spline.
LorenS
B2150HSD, Land Pride AT2572, Koyker 120 FEL
Mar 22, 2021
38
The part numbers for the parts shown in Post #1 are as shown below. Even though this bolts to the crankshaft pulley, it is found in the "transmission" section of the parts manual. Yes, I realize this thread is 12 years old, but I found it today and maybe someone else will in the future.
11,129
You do know that all these parts are long obsolete, like this thread. ;)
