From the pictures it appears that you need to drill a hole that the shoulder around the bolt will fit through in a grounded part of the body then mount the antenna and slide the cable connector over the threaded part with the pointed side against the tractor. Of course you will need the appropriate size nut and lock washer to fasten everything together,
