Kubota B7100 HST front end movement, radiator damage
dingodan123
Kubota B7100HST D
Oct 22, 2024
Australia
Hello all,
New to this forum but sure I'll be using it on a regular basis. Proud owner of a 1979 Kubota B7100HST D here in Australia. Got straight to work out here on 15 acres, slashing approx 7. Had a solid few days slashing and then I heard the crunch.
Radiator fan was right up against the radiator. When I drive forward or reverse front end of tractor moves and radiator moves with it. Unsure if engine mount issue or something else. Much more noticable when I go 4wd and front diff is active.
No FEL on this just a slasher on the back. Like I said, was fine for a few days slashing and all of a sudden radiator had the fan rubbing against it.
Short video, that's 2wd. 4wd flexes a lot.
Any insight or help would be much appreciated!
6,594
The entire frame is not connected to the engine! :oops:
16 bolts worth of unattached!
Would suggest you attach it.
2,938
1,398
Now, that's one I have not seen before!!!!!!!!!!
I am shocked it is not in two or three pieces.
