B1400D Servicing
dchugg
loader, blade, tiller
Apr 29, 2013
Fallis, Alberta, Canada
Does the 1400D have a common reservoir to service everything or do I have to provide servicing to the front and rear differentials separately and if so how is this done???
Dan Chugg
freewheel3
Mar 9, 2013
333
34
Alberta
Dan Chugg
The rear diff, transmission and 3pt hydraulics are a common reservoir. There will be a drain plug on the bottom of the transmission and probably also one on each final drive housing to the rear wheels. There will also be a screen filter for the hydraulic system low on one side of the trans, it'll prob be a banjo style fitting going thru a line into the trans housing. Pull it and clean it in solvent or diesel. Use Kubota UDT or equivalent if you have auxiliary hydraulics or just 80w90 gear oil is fine if not. The front diff will have a fill and a drain plug, use 80w90 gear oil. Each front wheel case will have drain and fill plugs, use 80w90 gear oil.
I'm unsure of capacities but you can probably find them in an online service manual if you don't have a hard copy.
dchugg
Apr 29, 2013
Thank you for this information. I have been having a lot of trouble getting information since I got the tractor. I did not know it was a grey market tractor when I got it and Kabota has not been much help.
Where might I locate an online service manual??
Thanks again this really helps.
