Kubota L6060 heat not working
Loganw15
Kubota l6060
Oct 22, 2024
Oklahoma
My kubota L6060 cab heater isn’t working. The coolant lines around the engine compartment are around 130-140°, but the lines up by the heater core are only about 60-70°. I can blow air through the lines from top to bottom, so there shouldn’t be any blockages. Anything else I should check?
SDT
multiple and various
Apr 15, 2018
3,315
1,102
SE, IN
Low coolant?
No, you cannot determine radiator level by looking at the expansion tank.
9,537
The M6060/M7060 WSM lists the following probable causes for "Insufficient Heating".
  • Water valve damaged
  • Temperature motor damaged
  • Insufficient coolant
BAP
Dec 31, 2012
3,030
1,143
Do you have any heating problems with the engine? How does the engine run? Remove the radiator cap and run the engine for a while until warmed up checking in the radiator to see if there is any bubbles coming out of the coolant. Compression getting into the cooling system will mess with how the heater works.
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
327
90
Bagley, MN, United States
Google airlock in heater core?
