Hydraulic Oil looks like chocolate milk
Rodent
L4200 tractor
Sep 17, 2024
Scotland
Looking through the sight glass of my l4200, the hydraulic oil looks like a light brown chocolate milk. Is this ok, or should I think about an oil change?
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
366
526
SE, NM
What's it taste like?:D
That's typically a sign you got water in it. So, to answer your question, yes change the oil.
old and tired
L2800 HST; 2005; R4
I would investigate how the water got in there first. Buy some cheap oil to do the first flush. Maybe even the first two flushes....
Gear transmission? Look for cracks in the shifter boot...
If it's HST, I wouldn't run it until it's changed...
8,759
This could also be the result of cheap hydraulic fluid used.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
785
680
E.
how does the oil look when not viewing through what could be a 30 year old sight glass?
is it clean off the dip stick if you have one or out of a filter, other???
if so then its a stained sight glass.... otherwise time for a oil change.
3,606
I agree, that it needs to be addressed before damage is done, and the "root cause" should be looked at.
I would start with a complete 'flush and fill" with filter changes using Kubota fluid.
