Installing power beyond loop
KevinRm100gx
M100gx
Oct 16, 2024
Hey guys
New to OTT. Just bought a used m100gx that does not have a FEL valve block. I’m installing a snow plow with a subframe. I bought an aftermarket 2 spool joystick kit with a 3rd function option. Pretty easy to install. All I need is to connect flow from the pump to the new 2 spool valve body and a return to hydraulic tank. My problem is I don’t know where there’s a power beyond port or a port for the return without having a FEL valve block.
Thanks in advance for the help
7,289
Hey guys
I dont know much about that tractor but pipe 40 looks like its your supply. Should be easy to replace it with a couple hoses. Power beyond port on your AUX valve would go back to cover on tractor. Then you would need to find a.spot for the tank return.
Edit:
Looking at the loader parts breakdown the factory outlet block is only $55.
KevinRm100gx
M100gx
Oct 16, 2024
Edit:
Hi Dan,
I've looked for the loader parts diagram the Kubota parts finder website and cannot find it. Do you use another website?. I'm assuming the diagram must show where the block is plumbed into. Thanks for the help btw.
Kevin
7,289
Hi Dan,
Kevin
Click on the link I provided. That page has links to parts diagrams for the different loaders that used the block. Here is a screenshot of the LA1954E diagram. The Kubota parts site lists LA1954/LA1954E as the loader used on your tractor.
3,932
2,435
Hi Dan,
Kevin
Kevin, Dan's been around the block a time or two. Usually, a front end loader is the first hydraulic user installed, so the parts for tying into the hydraulics are listed there, maybe a kit.
KevinRm100gx
M100gx
Oct 16, 2024
Sorry for late response here. I haven’t had a chance to even look at it yet. But the diagram you sent with the hydraulic block looks pretty simple. Thanks for the help. Much appreciated.
