Antifreeze Leak
tony_larson
L3301
Oct 15, 2024
Chaska, MN
I was moving some hay last night, noticed Antifreeze leaking and traced it back to the spot in this picture. I shut it down for a while and cleaned the screen as it had quite a bit of hay built up and when I started it back up the leaking stopped. Ran it for about an hour after that and everything
was fine. Has any one else experienced this and anything to be concerned about? Have about 900 hours on it now and this is the first time I’ve noticed it - I’ve seen the screen a lot more clogged in the past but never noticed any leaking before.
6,599
Zoom out with the picture, because I can't tell where that is????
tony_larson
L3301
Oct 15, 2024
Chaska, MN
Here’s a little better pic but not great. When I get to the barn tomorrow I’ll try getting a better picture and post it.
2,581
He means take the picture from further away - so more of the engine area can be seen.
kubotafreak
Sep 20, 2018
1,049
394
Arkansas, US
It is right above the belt. So thermostat housing, or a hose leak.
OP,
Many hose clamps can stand to be snugged up even when new.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
657
532
E.
I would start by replacing the 2 disposable gaskets
- thermostat gasket (rnd'ish gasket that sits on top of stat which sits ontop of part #1of the water flange )
- water flange gasket (squar.'ish gasket that goes between the block and the lower stat. assembly water flange)
In total parts less than $10 as well as tightening all hose clamps a little that arn't the permanent clamp type..
2,916
I'm certainly no expert any longer, but that sure looks like a crack running vertically to me.
But try the "easy stuff" first as suggested.
I can't figure out how to "circle it" on my Mac.
Edit: Well with a bigger monitor, I'm now less sure, but I was able to circle what I think/thought was a crack. Maybe its just the way it looks cause of the dirt?
