Snow chains…do I need them?
5,164
I would like to hear from people who are using the R14 tires as to their experience plowing or blowing snow with those tires.
Bearcatrp
Mar 28, 2023
1,388
1,009
Minnesota
I bought R4's for the winter and seemed to do a good job last winter. May keep my turf tires on to see if turfs are really better.
WI_Hedgehog
Apr 24, 2024
1,130
1,646
Milwaukee, Wisconsin, U.S.A.
Tirechains.com is the go to place for tire chains.
More information about chains than you will ever want to read.
Thanks everyone for the feedback. Ordered the front directly from TireChain.com for the best price, the rear and tensioners from TireChain.com through Amazon (thanks @TerryKing) as it was around $100 less than TireChain.com directly.
whatsupdoc
L3302
Jul 9, 2024
178
204
I have r14's, my place is on a mountain where in the winter it has its own weather system. There is some snowfall every winter night.
New tractor so I have not tried them in snow yet, but will post
my results using R14's in the snow.
Last week I was mowing (3point finish mower) a hill on a dry bright sunny afternoon and in 2WD I was sliding down the hill with the wheels locked, so im not too confident using the R14;s in the snow but we shall see.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,977
2,357
Western MT
If you don't know if it will go or not, I hope your luck holds out.
I also hope the snow isn't deep or slick unless you have other arrangements to clear your driveway, or you have nowhere to go.
WI_Hedgehog
Apr 24, 2024
1,130
1,646
This may help indirectly:
I have both lawn and industrial wheels and swap them regularly as the lawn tires are great for mowing without tearing up the lawn and the industrial are great in the woods with limited travel over the lawn and not much damage or much compaction.
If the rather steep grassy and mossy hills are wet the lawn tires slide, industrial grip like crazy because they can dig in, though they damage the lawn at that point.
On leaf covered hills in the woods I need at least industrial tires, if the hills are wet the tractor slides any time the R4s aren't digging in.
The takeaway is if a sloped surface is slippery the tires need to dig in to grip.
My driveway is sloped and ices up, so I'll need to dig in, and the points of the chains will do that whereas rubber will not. I have v-bar chains on a 10HP walk-behind snow blower and they slightly damage concrete if moving quickly, so I have to: a.) go reasonably slow with the walk-behind, b.) use non-studded chains on the Kubota and go reasonably slow due to the weight of the diesel tractor and implements.
With that said I bought European pattern chains instead of ladder chains to minimize the force of the chains hitting the driveway--like ice skates the wheels only need to melt the ice due to pressure and dig in, not smash things to bits.
Hopefully this type of reasoning can be applied as appropriate to whatever conditions you're facing.
TerryKing
B7100HST-D
Aug 18, 2024
180
121
Topsham, Vermont USA
arduinoinfo.mywikis.net
4,143
2,833
Now THERE'S an Idea! I've seen seriously-studded snow tires used on a snowplow truck.
Has anyone ever studded tractor tires??
TerryKing
B7100HST-D
Aug 18, 2024
180
121
THANKS Mikester...
Most I just read was studs in Ag tires. Has anyone studded Turf tires??
WI_Hedgehog
Apr 24, 2024
1,130
1,646
I think one might not want to do that because turf tires don't have the deep lugs agriculture or industrial tires have. The studs need to screw and bite into tough rubber, turf tires are usually soft and have thinner rubber for matching the lawn surface and not digging in.
Even putting chains on turf tires seems a bit questionable as the sidewalls (from what I gather here, not personal knowledge) are thinner than industrial or agriculture tires--maybe someone can fill me in on this.
SDT
Apr 15, 2018
3,695
1,418
I think one might not want to do that because turf tires don't have the deep lugs agriculture or industrial tires have. The studs need to screw and bite into tough rubber, turf tires are usually soft and have thinner rubber.
Bingo.
I would not try to stud turf tires.
BAP
Dec 31, 2012
3,191
1,307
Putting tire chains on turf tires is not a problem. You aren’t going to ruin them.
Donystoy
Dec 10, 2013
737
379
Binbrook, Ontario
I have R14s on my LX2610 and have cleared my 4000-foot driveway a couple of times in the last couple of years since I got it. I find them far better than my last B7200 that had turf tires. Both with a front blower. The B7200 was frequently sliding sideways at the edge of the driveway which I do not experience with the R14s on the LX2610.
5,164
Thanks for the information. I am considering them for my BX23S. I did pick up a set of R4 tires that I was going to stud and use for the snow blowing.
nbryan
Jan 3, 2019
1,432
950
Hadashville, Manitoba, Canada
Flatish no hills the R14 tires (no fill) on my B2650 do just fine with my front mount blower.
