HST creeping adjustment issue
5,495
2,200
seen a few of the BX's with loose hardware, which causes exactly what you're describing. Intermittent and erratic creeping in gear, not starting in neutral like they should, etc
IIRC it was a nut on the trunion link. I've been away from tractors for about 4 years now so I'm going off of my ailing memory. But it would be worth looking at the linkage on the transmission end to make sure it's all tight, before adjusting anything.
5,153
Doesn't that require removing the wheel and tire? If so it isn't going to happen. He has already made that clear in his post #25. The best advise that he can get is to take it to the dealership and have them fix it. With any luck it will be an out of warranty repair.
5,495
2,200
I've done them without removing the tire/wheel.
