B2150- oil shaft seal ( discontinued ) anyone find an alternative?
5,152
Take the seal to a wholesale bearing supplier and they will measure the existing seal and then cross reference those measurements to a seal that will work. If you can give them the exact diameter of the shaft that will help because your seal is most likely worn where the shaft was riding on it.
Chanceywd
Mar 26, 2021
690
612
central ny
part number ( 67817-14190 )
its the 4x4 shaft seal, ( the smaller one in the picture )
View attachment 139030 View attachment 139031
Some of the metric sized seals will have a series of 3 numbers on them. The first number is the shaft size, the second number is the bore size it fits in and the third number is the width or thickness.
Clean it off carefully with some brake clean maybe, and the will be right on the face.
I worked in maintenance in a large monofilament company and most of our machinery was German made. Lots of metric bearings and seals on it.
Here is an example of how they are listed.
This one even shows lip styles.
Wull
Tractor
Mar 21, 2023
74
14
Scotland
Exactly this, this is what we do for all our seals and bearings.
5,671
a possible 'trick'.
If there's room in the hole for a 2nd seal, install it !
On one tractor the original seal was >1/4" thick(wide, deep,??). New seals were 1/8"+ thick so two seals could be installed. Extra seal ran over 'virgin' shaft.
