B7200HST - FWD/REV Adjustment
wally2q
B7200
Sep 15, 2024
20
ontario, canada
Hi Everyone,
my new-to-me B7200 seems very sensitive to HST fwd/rev control input on the pedals.
Just touching it in any direction surges the tractor fwd or rev that it almost slides me off the seat!.. after that initial surge for a fraction of a second the tractor settles down at whatever speed I have the pedal set to.
Even if I try to feather the pedal gently and a tiny bit to go slow, it first Jolts / surges, and then the speed is what I have the pedal set to.
Question - is this normal for these machines?... or if abnormal, is there some sort of adjustment that can be made to reduce this effect?
thanks in advance!
5,652
Hi Everyone,
thanks in advance!
Not normal - you should be able to slowly inch both forward and reverse. It's one of the advantages of HST speed control. I would check the pedal linkages.
9,198
More than likely you have a bad dampener, that smooths out the HST control movements.
wally2q
B7200
Sep 15, 2024
20
ontario, canada
Thanks for the quick response....
I'm quite familiar with HST - I have 3 other HST tractors (not kubota).
Yes - I can inch forward at very low speed... but as I press the pedal it does this quick surge for a fraction of a second, and then settles on the speed I have the pedal set to.
It only moves maybe 6 inches with that surge... it's very quick.... but that initial surge snaps my neck
Hydro
ZD21
Sep 3, 2024
Southern Indiana
Check also the linkage on the side of the HST , the lever clamps onto the control shaft and may be loose ,, allowing the HST to over travel when you first push the pedal
