Do I need rod bearings? What explains this?
pissedoffpatriot
Kubota b20 d-950
Sep 22, 2024
Fife wa.
My B20 d-950 Kubota has run strong for 20 years. Lost compression so I'm doing a ring job. Then I noticed these bearings. See attached picture. What could cause this? What should I do? Thanks.
4,465
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
930
1,196
Pittsburgh
Wow. I've never seen that type of localized erosion except for chem/galvanic or cavitation.
1,410
I have seen that on some bearings with high load (specific pressure). The Babbitt material may not have been bonded to the steel backing and fatigue set in and cracks out a portion of the Babbitt.
2,919
1,380
It is typically caused by water vapor, along with not changing the engine oil or using a subpar engine oil.
jaxs
B1750HST
Jun 22, 2023
733
521
If you expect any degree of longevity and reliability I don't see any way around removing crank shaft for at minimum polishing and most likely turning. Considering amount of sludge and low compression along with lower end damage I expect you are looking at total rebuild or finding a used engine.
Nicksacco
Sep 15, 2021
678
382
Bahama, NC
Here's a video I thought y'all might like.
The guy on the left is "The Motor Oil Geek" (another youtube channel).
His stuff is great but I confess, I don't pretend to understand everything.
This video however talks about journal bearings and provides some good knowledge.
I wanted to run out and change oil in everything I owned!
