Safety Switch issues
Willie_B2650HSDC
B2650HSDC, LA534, Backhoe, RC72-30BB
Sep 15, 2024
Ontario, Canada
Hello
Has anyone ran into this?
sitting on the seat and PTO disengaged....no start.
engage PTO It starts.
With PTO engaged, i can climb out of the cab and tractor still runs.
With PTO disengaged, Tractor shuts down when I leave the seat.
Complete opposite to how its suppose to work.
My guess is a bad PTO safety Switch???
5,427
Did it just start doing this?
I didn’t look at a schematic, but I believe the PTO switch is activated by the PTO lever..don’t hold me to that, but maybe the switch’s mount is just loose or out of alignment/adjustment?
Just talking from memory, so don’t take as gospel.
5,049
this...
IS a VALID 'mode of operation'.
I agree ,sounds like connector was installed wrong, though that should not be possible.
more info is needed, like 'did you replace the switch, or reinstall the connector ??
Dustball
2016 B2650HSDC
Sep 15, 2023
312
188
Hudson, WI
Hello
Here are the conditions for a B2650HSD and B2650HSDC. The ON/OFF refers to the state of the safety switch, not the function.
Not one of the conditions below allows starting with the Independent PTO engaged (OFF).
Willie_B2650HSDC
Sep 15, 2024
Ontario, Canada
this...
Normally when I'm running the belly mower and don't disengage the PTO and climb out the cab the engine shuts off...This is a new issue and can only start if I engage the PTO while sitting on the sseat..
I've located what I think is the PTO safety switch and attached the two connectors together and seems to have solved the issue
5,049
curious as to how anyone could run, say a 3PH/PTO run chipper if the engine shuts off when you leave the seat ?
4,668
I think the mid PTO has Safety and the rear does not
The answer to these things can usually be found in the manual.
For example on a L3901 the rear PTO safety switch normally shuts the engine off if you leave the seat. You can defeat that by tilting the seat forwards within 2-3 seconds of getting up.
Have you thoroughly studied your manual?
