M126X won't start
Sam Thornton
M126X
Sep 13, 2024
Monticello, Ga. 31064
Spilt tractor to rebuild fwd and rear clutch packs, put back together won't crank, have code EN-ENG o dash. Have power to CRS relay, can ground terminal that goes to ECM and will crank and run, remove ground to shut off.
6,382
Look at the WSM, sounds like you have an issue with a safety switch, or control input.
