Recently acquired a bx2230d. I am mechanically inclined in other areas but I’m new to tractors. I have not had the time to go through everything yet and figure out how everything works. I have searched and read many forums to see if I can find my specific problem with no success.
Loader doesn’t lift in normal function. The loader will lift if I use the curl function at the same time. The most I have had time to look into it, is I swapped the hoses. The loader will lift when I swapped them, but it is not strong enough to lift a full load. I am thinking it is a stuck valve, but I am hoping someone might be able to point me in the right direction. All other functions of the tractor seem to work properly. The loader is a la221. Thank you for any possible tips.
