3901 with Galaxy Marathoner R4 tires. I cannot find a max PSI listed on the sidewall. The only mention of PSI is to not exceed 35 when mounting. I found a catalog with specs online which I believe shows the max PSI for my fronts (27x8.50-15) as 45. I've been keeping them at 30 based on the sidewall, but what planet am I on where the max PSI is not listed on a tire's sidewall, and you have to go to an online catalog to find it? I'm new to industrial/agricultural tires so is there some universal system for calculating PSI from the data on the sidewall?
Also, what pressures are people using for dirt-only machines where traction is important? Our tractor never leaves our property, which is sloped and frequently muddy, snowy, or icy. Used mainly for moving material in the loader, smoothing areas with the box scraper, and plowing snow with a front blade, with chains for rear tires.
