Boom cylinder rebuild
Fatzi
Kubota B8200
Sep 10, 2024
10
Tafton PA
Hi folks
I need to rebuild my boom cylinder an I need to find an E or L stamped on the cylinder to get the right rebuild kit. Dose anybody know where it would be stamped on the cylinder barrel because I’m not seeing it.
B/L-4520B Backhoe
4,467
Hi folks
Are we talking backhoe, loader, or something else? Type of equipment and model number please.
Fatzi
Kubota B8200
Sep 10, 2024
10
Tafton PA
Depending on who built the attachment E- is for energy an L- is for Lantex.
2 different rebuild kits
Vlach7
L47 305DT JD500C
Dec 16, 2021
345
251
Frazier Park Ca
Take your parts or old seals to a hydraulic shop and they can measure them and give you the correct seals for half the price
Fatzi
Kubota B8200
Sep 10, 2024
10
Tafton PA
Ok I called messicks again an ask him that an he was stumped also so he is calling kubota an is going to get back to me with an answer
Fatzi
Kubota B8200
Sep 10, 2024
10
Tafton PA
Ok missecks called kubota an this is what they had to say.
I spoke to Kubota parts technical. They confirmed the seal kits are the same regardless of which cylinder manufacture you have. Part# 70030-01305 will work.
Good information so everybody knows
4,467
Here's my answer- the kit likely contains parts for both type cylinders and you only use the bits you need.
Bottom line is you can ID your cylinder but there is only one order number regardless of L and E markings.
