B2320 FEL joystick sticking
Billbo
B2320 HST
Jan 4, 2022
70
South Louisiana
Hello all, I read in another post a guy lubricated the balls and springs on his joystick - question for you how do you lube the springs and balls in your joystick? My joystick ‘sticks’ and when it breaks loose the bucket just jumps up of down or curl/dump!!!! Seems I can’t just ease into moving it any direction.
7,238
The only balls and springs are in the detent, and the odds of them needing lubed are rare.
But here it is:
7,238
You could try lubing these parts and see what that does for you.
BAP
Dec 31, 2012
2,821
931
If you have cables connecting the controls to the valve they may need to be cleaned and re-lubed.
There is no cables on this series of tractors, the handle connects directly with the valve using pivot joints.
BAP
Dec 31, 2012
2,821
931
Billbo, spray the pivot joints at the base of the handle really good with either a good lubricant oil or some white grease. Move the handle around and spray more. On my B2920 , the handle has progressively become harder to fine control over time. Keeping it well lubbed up has helped but not cured.
