BX MMM Detachment Issue
eth0
BX 2680, 60" MMM, box blade
Aug 23, 2024
NKY
Greetings!
I'm a new BX2680 owner (2 weeks) and yesterday I attempted to remove the 60-inch MMM for the first time so I could install a BXpanded skid plate. I followed all the steps exactly as they are laid out by the countless YT videos I've watched and written instructions in the manual. The front removes easily enough and I can pull the pins out of the rear linkage and lock them in place. However, when I raise the 3PH, the mower still raises with it. The arms are somehow still caught up in the linkage even though the spring loaded pins are pulled back and the lock pin is set in the detent.
I've tried grabbing the arms and moving things around but they seem to be rubbing or stuck on something. Has anyone had an issue like this? The videos make it look like there's a lot of clearance and no rubbing should happen when the arms are raised. Or at least not enough to still be able to raise the MMM off the ground. I'm hesitant to put too much pressure on the arms, hit it with a mallet, or otherwise force them to detach but I'm not sure what else to do here. This appeared to be a super simple process so I'm left feeling a bit defeated.
Some details:
  • Yes, I have the MMM height set to 0 or 1 (tried both)
  • I have tried moving the casters to their highest and lowest positions to no avail
  • When I tug on the arms that drop down and attach to the mower, I can move them up and down some but not a lot. They seem to be rubbing against the small slotted pieces that the spring loaded pins go in to when it's attached.
Thanks in advance!
Vince1230
Bx2370
May 13, 2022
158
77
Honey Grove,Pa
My deck sometime get caught on the bolts sticking up in the back. I usually lift tractor off ground with bucket to help me see.
eth0
Aug 23, 2024
NKY
Thanks, I'll give that a shot when I get back in town Monday.
5,161
Don't force it get a bigger hammer. I had the same problem with mine once and I used a rubber dead blow to shock it off. Once I found what it was hanging up on I removed any burs and put a dab of grease on it to make it slide off easier next time. The deck is robust enough that you can manhandle it a bit.
retiree-urgency abandoned
B3350, Kub. 5" rotary cutter, LP 48" forks, Titan Aerial Platform, KK XB Dump
Dec 1, 2020
110
115
Bloomington, IN
I've got a B3350 with MMM - not sure how different it is from your machine, but here's what I do.
1. Park in barn on concrete floor or on paved driveway (easier to maneuver than on dirt, lawn or gravel)
2. Set parking brake and turn machine off
3. Pull & lock spring-loaded pins on both rear-linkage lift arms and then loosen each arm and hang it (with pin) from the arm hangers. Being on concrete or paved drive, allows you to wiggle the MMM on its casters to loosen the arms.
4. Disconnect front MMM hanger (on mine, you pull a spring-loaded pin and pull the lever down to release the front - don't forget to put the lever back up (locked by the pin)
5. Disconnect the MMM PTO shaft from the tractor
6. Start machine, lift 3PH to highest setting, rotate FEL bucket down and use bucket to lift front end of tractor off the ground and turn off machine
7. Roll disconnecteed MMM to the side - out from under the tractor
Hopefully this helps!
