Mower blades
5,163
Do you sharpen your own mower blades or do you send them out for sharpening? How do you balance them if you do the sharpening yourself?
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,563
5,515
2,226
I sharpened blades for 32 years.
I just buy new ones when it's time, which is about every 4 or 5 seasons. But I don't cut nearly as much as I used to either. I have a 'country yard' meaning I let it grow when it wants to, and I'll cut it down as needed but it's not manicured. I keep the rocks and sticks picked up but that's about the extent of maintenance.
PaulL
B2601, MX5200.
Jul 17, 2017
2,790
1,788
NZ
I sharpen my own. Take them off and do it on the bench grinder. I didn't balance for about 5 years. This year I bought a pyramid balancer for $10 off Aliexpress. It said my blades were balanced enough, so I guess I didn't need it. :)
4,116
2,812
I take the blades off the machine and use a 4-1/2 inch 60-80 grit flap disc grinder to put on a clean sharp edge.
I don't try to re-balance. I have sandy soil and have to replace my blades every season since they get sandblasted paper thin.
I also scrape the deck bottom before reinstalling.
Wull
Tractor
Mar 21, 2023
74
14
Scotland
I just use the pyramid for balancing the blades after sharpening them in the workshop, works perfectly well and we do a lot.
7,323
Been using 60 grit flap disc last 6-8 years.
Used bench grinder before that.
Sometimes I balance, others I don’t.
6,279
really ? You're supposed to sharpen mower blades ??? Had a new neighbour bring me his rider 'doesn't cut too good'..... The back side was SHARPER than the 'cutting edge'......
Used a 4.5" wheel on that,then ,like RCW, 60 grit flapwheel.
Always have a spare set ready to go..after all blades are supposed to be rotated...
Mowbizz
Bx25d
Aug 19, 2021
612
357
I invested in an ALL AMERICAN sharpening system and an Oregon balancer!
bothe work extremely, well. When I engage my blades on the Kubota Z422, they spin as smooth as silk! IMG_8036.png
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
195
199
Around here they charge $10-15 per blade to sharpen. I installed new blades this year. I will pick up a blade grinder and before next season I will sharpen the 3 old blades and the 3 new blades.
It will take about 5 years for the blade grinder to pay for itself sharping them once a year.
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Oregon bi directional blade machine and pyramid balancer.
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Also have a stihl commercial chain grinder. Picked it up for $75 bucks from old coworker in a divorce sale. It had a broken degree table. About $150 in parts good as new. They sell for $700 or more.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Angle grinder / flap wheel / plastic pyramid. Flap towards the sharp edge on the top side, then just kiss the bottom edge away from the sharp edge to remove any roll. I go for sharp. No worry about perfection in balancing. They get deposits while mowing that probably unbalance them a bit anyway.
Velma
B2301, FDR1660, RB1560, SGC0554, Pats QH, CMP Dethatcher
May 12, 2022
96
59
MI
Flap disk and a screw driver for balancing. The LP manual for the rear finish mower says to balance them vertically. So I just hang them on a screw driver and see if the blade tilts to one side or the other. I rotate thru two sets of blades a year and have a smaller yard. So they never get so worn I’m taking off enough material to throw them much out of balance anyways. Especially with the flap disk.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,563
Sharpen 2x a year and cut your ROI in half! šŸ˜‰
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
I buy 3 sets of blades at once. When I install set #3, set 1 & 2 get sharpened and balanced. I balance my blades by hanging them on a piece of solid shaft, driven like a nail into a vertical post.
