Kubota u17 wont shut off with key after new fuel stop solenoid
DirtShapes
Kubota u17
Jun 26, 2024
Hey all, new here. Hoping someone could shed some light on my problem.
Ive got a 2022 u17 with just 275 hrs. It quit while running and wouldn't start back up. realized it was blowing the 30amp "engine stop" fuse. Unplugged the fuel stop solenoid on the pump and it quit blowing fuses so i ordered a new solenoid. Got the new solenoid installed today and it started right up, but will no longer shut off with the key, i've got to use the lever on the pump to shut it down. It actaully seems to idle up a little bit when i turn the key off. Is there another relay or module that controls that solenoid?
Thanks!
hbeaumier
Kubota U17
Aug 9, 2024
Quebec
Hey! Same situation here. Did you find why you were not able to shut it off with the key?
Thank you!
DirtShapes
Kubota u17
Jun 26, 2024
So I did get mine working. The first shutoff solenoid I got from the dealer was also bad, just stuck open instead of stuck closed seemed like. I ended up buying another solenoid online and put that in and it’s been working fine ever since.
Thank you!
hbeaumier
Kubota U17
Aug 9, 2024
Quebec
Thank you for the reply! I will try another solenoid then
2,942
1,399
There is a technical service bulletin for this issue. Make sure your new solenoid has the white paint mark on it or it will probably fail.
TSB-2023-049-E-R3 - K, KX, SCL, U-Series; Engine Stop Solenoid Failure
May 19, 2024•Knowledge
Article Number
000007119
Article Record Type
Bulletins
Last Published Date
5/19/2024, 4:00 PM
Language
English
Title
Bulletin Type
Fix as Fail extension
Description
Repairs described in this bulletin may be made only in the event of a failure.
Product Line
Subject
Solution
If the installed engine stop solenoid fails, replace it with the improved engine stop solenoid below per the procedure on page 3 of the attached TSB.
Note: Incorrect installation or damage to the plunger rod of the new stop solenoid will prevent the engine from shutting down. Remove and inspect the new stop solenoid if this occurs, then carefully reinstall.
Parts Information
No code has to be inserted here.
Warranty
This bulletin applies in the event of a failure and does not constitute warranty authorization to update units without a defect in material or workmanship.
Source Bulletin Number
CM-23-048-04
Products
K008-5, KX018-4, SCL1000, U10-5, U17
URL Name
TSB-2023-049-E-K-SCL-U-Series-Engine-Stop-Solenoid-Failure
Serial Numbers Affected: Model Serial Numbers Model Serial Numbers
K008-5 10001 to 11358
KX018-4 46312 to 48132
SCL1000 11280 to 14933
U10-5 10001 to 11249
U17 53750 to 60039
jamesdunn
scl1000
Oct 13, 2024
jdad112219
Article Number
000007119
Article Record Type
Bulletins
Last Published Date
5/19/2024, 4:00 PM
Language
English
Title
Bulletin Type
Description
Product Line
Subject
Solution
Parts Information
Warranty
CM-23-048-04
Products
URL Name
U17 53750 to 60039
I HAVE SCL1000 AND THINK THIS IS MY PROBLE DO U HAVE ANY PICTUREST TO FIND IT OR WHAT IT LOOKSN LIKE THANK YOU?
KUBOTA902
20
DE
If you don't install the solenoid properly it won't shut down. Make sure you get the plunger in the right place.
