L3750 Front right axle hub internally destroyed, parts discontinued
Lance Ebel
Kubota L3750
Aug 1, 2024
Danby, NY
I have a L3750 that I bought recently. Someone must have driven the tractor a long time without fluid in the front right axle hub, because it was totally destroyed inside. The splines on the bevel gear shaft are worn completely off! It seems I need a complete axle hub, or front right corner as some parts places have called it. But I have searched nationwide and no one has it. Anyone know of a secret Kubota junkyard somewhere?
JimmyJazz
1,219
739
Pittsburgh, Pa
On the tractorhouse.com website there is or was a means to search for dismantled machines. Give that a try. Good luck.
1,415
You can see if @007kubotaguy has what you need. He is a member here and has a used parts place somewhere on the West Coast.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
927
721
canada
There are four models that use that vertical shaft. 3150dt,3750dt,4150dt,4150dt-N. They probably use the same gears also. If you are looking for used tractor parts.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
395
145
CNY
Have you tried calling Goodrich's in Newark Valley? They may have or be able to locate something for you. They aren't always the easiest to deal with or the most reasonable but deal with a lot of Kubota stuff.
5,238
Great suggestion I never thought of. I see the OP is from Danby, which isn’t far from Goodrich’s in NV.
I’m an hour away from them and been to a couple of their auctions. They do have a lot of stuff.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
395
145
CNY
You can try here as well. I called them once looking for 3pt lower arms and they didn't seem to want to deal with my request. But it is worth a shot.
Wenger's is another place to try but they also seem less interested in used parts than they used to.
Lance Ebel
Kubota L3750
Aug 1, 2024
Danby, NY
Goodrich's has no older Kubotas, unfortunately
Lance Ebel
Kubota L3750
Aug 1, 2024
Danby, NY
Update: There are zero parts places across the US that have this axle in stock. I have checked every scrap yard and every used tractor parts place available. Furthermore, Kubota discontinued many of the parts, so there is absolutely no way to fix this tractor aside from finding a parts tractor for sale. Which would be like finding a needle in haystack...well, that's what happened. Someone was selling the same tractor, within 30 minutes of me. So I bought it. My only issue is it breaks my heart to part out this other tractor. But it is in slightly worse shape than the first one, so I will have to just do it. In effect, if anyone on here needs parts for an L3750, let me know! The parts tractor has 1700 hrs.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
927
721
canada
Going this route, I think I would change out the entire axle assy. That way you are not opening up any internals, and probably just as easy.
