Rear Hydraulics and Tilt Cylinder Lengths
mcicero
B2650, BH77, Land Pride SGC0660
Aug 30, 2019
9
York, ME
I am in the process of installing some rear hydraulics for my B2650 tractor. I have the backhoe and 3rd function installed from the factory. I was going to use the power beyond connections for the backhoe as my connection point as I won't need use for the rear hydraulics while that is on. I am planning to run 3 spool valve from Summit and attach it under the seat area. As I am piecing all this together, I was wondering what everyone was using for top and tilt link cylinders and the sizes you went with. Thanks.
5,831
At the risk of beating a dead horse there is no real advantage to hooking the remotes up with couplers. You can make them permanent for the same money and effort. Once installed they are "just there" whether the hoe is on or off.
JMO,
biketopia
Feb 15, 2024
370
374
Warrenton VA
I also have a B2650 and I'm currently installing a 2 spool set up under the seat, are you sure you can cram a 3 spool there, It's awfully tight with a 2. I went with summits hydraulic top link and 2 spool valve. Just ordered up a handful of misc fittings yesterday and hopefully going to wrap it up this weekend. I also have summit's 3rd function on my tractor. I ended up removing the seatbelt for now to gain extra clearance, I'll re-evaluate it when I have my fittings for final mock up.
Daferris
LX2610
Nov 23, 2021
483
405
Mid-Michigan
Check out what I did with my LX 2610 for the side link. Also in the write up is a link for the top link.
mcicero
Aug 30, 2019
9
York, ME
JMO,
I wouldn't be opposed to making them permanent. I would still have to come off the power beyond. Would I just plumb it in before the coupler connections for the backhoe?
5,831
Never seen that particular machine in person but the backhoe connections seem easiest.
  1. Remove female coupler from backhoe supply pipe and use a hose to connect pipe to P on new valve.
  2. Put coupler on N port of new valve and use it to supply the hoe.
  3. Connect T port on new valve to any tank return location.
Thats it - specific plumbing details like hose routing and female coupler placement up to you as long as you naintain that PB circuit. Remotes are always "hot" and can be used with or without backhoe. When hoe is removed you loop those two connections together just as before.
Regardless of how you decide to go you must use a PB sleeve in the N port and provide a direct to tank connection for T port (e.g. two outlets).
mcicero
Aug 30, 2019
9
York, ME
I am very interested in seeing it. I used the measurements off the valves from the site and the space here and thought I would have enough room for 3.
biketopia
Feb 15, 2024
370
374
Warrenton VA
Most of my fittings are showing up today. I'll mock it up tonight and take some more pictures.
biketopia
Feb 15, 2024
370
374
Warrenton VA
Once you add the fittings and hoses you're not going to have room for a 3 spool, there's definitely not an extra almost inch and a half, I might have to shim my seat up a smidge to keep from kissing the tank and power beyond fittings.
mcicero
Aug 30, 2019
9
York, ME
That looks great! Thanks for giving me a real life visual of what I am working with.
biketopia
Feb 15, 2024
370
374
Warrenton VA
Sure thing! I received the last of my fittings for install over the weekend. I'll be getting this buttoned up during the week. I'll make a post and link it here to see the final product.
5,831
I am curious about that black hose end elbow. Exactly what is that - some sort of reusable end?
biketopia
Feb 15, 2024
370
374
Warrenton VA
That was a PTFE hose end I had laying around when I did the fuel lines on my camaro, it's a -6 fitting. Soley for mock up as I didn't have a hose or hose end handy to check for clearance.
Bob11x
B2650HSD, L3901
Feb 20, 2016
17
Upstate ny
Any progress on the pictures of the install? I am getting a B2650 without a BH. It looks like there is a "Block Outlet Cover" that taps Hyd pressure for implements. Is that useable for a 2 spool valve?
Don't mean to hijack, just would like to see the pics of the valve install (and the connector mounts!)
Thank you
5,831
Thank you
To use the outlet block you need the OEM take offf adapter.
The adapter provides generic pressure out and power beyond return ports. It could supply a 20 spool valve if you had a place to mount the valve.
Simpler to just tap the PB pipe on the loader valve.
biketopia
Feb 15, 2024
370
374
Warrenton VA
Like TheOldHokie said, it's easier to tap the PB pipe on the loader valve. I had already installed fittings when I did my 3rd function install. All I had to do was move one hose from returning into the PB loop after the 3rd function and use it to feed the remotes, then one new hose from the remotes back to the loader valve, and one small line Teed into the tank line. I'll look and see if I have pictures on my computer, otherwise, I'll snag some today.
This thread is what made me join OTT, read from post #99 on and you'll see Dan and I's exchange with pictures.
