Thanks,, I’m just getting used to the machine. She only had a 100 hrs on her. And was kept covered for years. Runs great. 40 years on the water, so I’m a duck out of water.Yes, but depending on WHY the tire/wheel is leaking.....might be better to just fix it. With a tube, IF you have a puncture....you'll need to remove the tube to repair it.
Got tired of small leak between rim halfs on front of b2150 so in went a tube today.... corrosion between rim halfs and rubber seal leak....repainted inside of wheel and new tube....done.
pump it up - slather on soapy water & see what you see
check & tighten valve stem core?
Where did you get your tube and what size was it? I have the same problem with my front tires and I think a tube is the best first step. Finding the same size tire I need for my b2150 has been a challenge. Current tire is 24x8.50-12 and I have patched it multiple timesGot tired of small leak between rim halfs on front of b2150 so in went a tube today.... corrosion between rim halfs and rubber seal leak....repainted inside of wheel and new tube....done.
Never found exact size but with tubes close is good. (Fix / sold tires 45 years)Where did you get your tube and what size was it? I have the same problem with my front tires and I think a tube is the best first step. Finding the same size tire I need for my b2150 has been a challenge. Current tire is 24x8.50-12 and I have patched it multiple times
Hope you found the tubes…. Mine worked very good . Tires holding nicelyThanks. I'm going to do tubes for short term and see how it goes. Is there a source for 24x8.50-12 tires. My rears are in pretty good shape and don't want to go thru changing out fronts and backs. Google has plenty of results but it seems it comes up as 23 or 9.5 or.... When I find a site with that size they are out of stock.
Thanks again for your response.
I did find tubes and they have been holding fine so far for several weeks (knock wood). I haven't used it a lot but I think it will do the trick for now. Thanks for your help.Hope you found the tubes…. Mine worked very good . Tires holding nicely
