Boat owners- garage question
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
Seeing as my racing days are numbered; thinking about getting back into the boat world. We plan on having a out building built for other reasons. Figure why not plan for the next toy. Pricing out things. I'm wondering how tall we will need the doors if we purchase a boat. I can't find a whole lot on line. If experience serves me correctly, overall height on a trailer would be bridge clearance + draft + 12" ? Am I close or way off?
I recall from previous boats that with the outdrive down, there is a few inch gap between the drive and the ground when the trailer is level.
5,188
I would suggest 14' clearance.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
For what? Depends on the craft. Our old Mastercraft fit in a 7' door. Supra needs 8' with the tower. Cabin cruisers need more. Pontoons less.
Hence the reason I'm asking about measurements for a boat in a trailer.
11,757
My boat is a couple of inches under 11ft from the ground to the top of the "rocket launchers". It's a 20'-7" Robalo R200 sitting on a Coyote trailer. The motor that was on the boat last year is shown in the photo, but I installed a VF200XB a few months ago. As you say, with the engine trimmed all the way in (down) there's a couple of inches clearance between the ground and the skeg.
11,757
Exactly! There are many variables so let me know if I can help in any way with specific measurements.
Robalo R200 specs:
Bridge clearance with T-top = 8ft-4in
Draft = 15in
So using your formula we get 10ft-7in which is very close to the height of my boat.
imnukensc
BX2380
Sep 10, 2015
797
768
Midlands of SC
Depends on what kind of boat you're talking about. A 14' john boat and a 22' center console with a T top are 2 vastly different things. A boat on a trailer typically, at least where I come from, has the motor tilted up on a "motor toter" while towing on the trailer until it's parked or in the water or going down the ramp. In any case, when the motor is down it ain't dragging concrete or anything else.
3,953
2,455
I think your calculation assumes the trailer carries the keel 12" off the ground? That sounds a little low for many trailers. Maybe 30" to give some clearance?
11,757
The lowest point of the hull of my boat (keel) is 20" from the ground, when on the trailer of course. I'm building a pole barn this fall and I'm going to have 14ft of clearance since I'm adding a radar dome this summer.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
They are different, but that's where the standard measurements come in.
Bridge clearance- from the waterline to the highest part of the craft.
Draft- distance between the waterline to the skeg of the outdrive (or prop with an inboard).
The sum of the two are the OA height from the bottom of the skeg to the highest point on the craft. Johnny, cabin cruiser, ski, cigarette.... it's all the same points of measurement.
And no, our last I/O boat was not dragging the skeg if the outdrive was down while on the trailer. But it was pretty close. Closer that 12" Wouldn't want to trailer it home that way. I'm figuring the draft +clearance + 12" is close to trailering height.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
Not the keel. The keel is part of the hull. The skeg is part of the drive unit. Which (when the drive is down (OB or IO) is much lower than the keel. The prop and skeg have to be below the keel so that they remain in the water at speed.
6,320
Do it ONCE, frame in and install a 14' tall, 12' wide door. 12; if front access, 14 or 16' if side access.
You 'can' always install a smaller door BUT it ain't easy to go bigger !
Can't get a silly, little BX23S through a 7' tall garage door with ROPS up, it JUST fits through an 8' (level pad in front',10' would be nice.....keeps lights and roof from being 'modified or removed'......
5,188
It has never been said: "I wish I had a lower headroom door on my storage building"
3,132
Not that it answers your question at all but taller buildings provide more storage capacity for the same amount of taxes since taxes are based on square footage not volume. This only applies to single story buildings in my taxing authority, so don’t have a second floor just shelving or small lofts.
Taxes where I am located drive a lot of decisions about what to build.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
I get that it would be easy enough to say make it a 14' door and 16' inside. If I had unlimited funds I certainly would. Anything over 12' increases the cost of the building significantly. Especially since it will be >1000 ft sq. We aren't buying a center console T top and won't need a 14' door. Most crafts in the 28-30' range we are looking at have power Bimini towers so that decreases headroom needs significantly. Down to the under 6' range for bridge clearance.
Soo....anyone have real world #'s?
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
Fortunately we are in an Ag zone. So storage buildings are not taxed really. I mean, it does add to the property value and that is taxed. A $30k building is $30k and they don't care about floor area. As long as it's not plumbed and liveable.
3,953
2,455
Just a thought, use sloped, parallel chord trusses to get height in the center for the boat without the side walls having to be so tall. I, of course, don't have any idea what you're considering.
5,667
I think for a boat, it should be like a garage,, figure out what you THINK you might need, and go at least 30% larger :)
5,188
Does the possibility exist that you might EVER buy a motor home?
11,757
My real world numbers posted earlier are for my boat only. I put the boat into the storage unit this morning since I'm away next week. The door height of the storage unit is 12ft or thereabouts. Doesn't help you at all but it sure helps me to realize that I need a 14ft door once the radar is installed.
Good luck on your building and your boat ... looking forward to hearing more about it.
Poohbear
Jul 6, 2018
571
206
Gilmer,Tx,United States
Build it for the next owner. If you had to sale what would add value ? I have 10x10 doors on my shop but could put 12 tall on the end wall. We built our RV shed 20/45 with 15 ft wall. I should have gone 50 ft as our current rv is 44ft from pin to rear
