2000 Kubota B7500 4X4- Very Clean
kb75tractor
Welland
Flawless 2000 Kubota B7500 4x4 compact tractor. This tractor has a 21 HP Diesel engine that fires right up and runs strong. The transmission and clutch are strong and the tractor has been stored inside. It only has 310 original hours and is 100% ready to go to work. The loader and mower work great as well (denhton@msn.com) Dennis, $6400.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Not to nitpick but 310 hours is freakishly low for a 13 year old tractor. But as much paint is missing on the bucket it looks like it has more hours on it then just 310...
hodge
Nov 19, 2010
2,903
450
Love, VA
When I bought my B7100, it was 21 years old with 640 hours- there are low tractors out there.
tmessenger
B7100D P
Feb 17, 2013
40
Fairfield, IA
I bought a 1979 B7100D a couple of months ago 34 years old 750 hrs. If you are moving gravel with a bucket the paint could be gone in a couple of days.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,120
1,242
Near Lancaster, PA, USA
My 2002 B7500 had around 1,100 hours on it last year when it was replaced by the L3200. The loader saw a lot of use in dirt and with crushed stone. One of the first things I did when the B7500 arrived was to move 20 tons of riprap to stop some erosion. Until out main driveway was paved, there was quite a bit of loader work on that. The last 50 or so hours on it were the first half of moving 76 tons of sand and a similar amount of 3/4" clean stone. Here's a picture of the B7500 with the L3200 on delivery day.
hodge
Nov 19, 2010
2,903
450
Love, VA
Did you cut the ROP off?
chim
Jan 19, 2013
2,120
1,242
Nope. I unbolted it. The B7500 - at least mine which had the non-folding ROPS - had a joint about 6" above the fenders so the hoop could be removed. The ROPS bolts in the picture are holding what Kubota called the "Winkerlight" bracket. I mow around trees with low branches.
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Wow... I thought I had low hours. 1983, B7100D approx 31 years old with around 1860 hours. Just goes to show you, some get used less than others.
