I built a boxblade of dubious quality
2drx4
B7100
Jul 24, 2023
60
90
PG, BC, Canada
www.4x4north.com
I needed to pull the weeds in my driveway and decided it would be faster to just build a blade to drag them to death with. The main requirement was that I not purchase anything except the pins and a new top link (needed a new one for my snowblower, so I could justify it). Luckily I had a piece of W6 beam that I'd been saving for 15 years, so I cut 4' of that off to make the main blade, and I just turned it sideways so it has two cutting edges sort of a thing. The mount for the toplink is some 2.5ish HSS that was sitting in a pile rusting. The box edges were leftover flat bar from building a fuel trailer for my employer, and the gussets for them were a drop from cutting up some 6x2 HSS for something (who knows). The lower mounts were some other scrap HSS and some strange tabs I had lying around which I think were supposed to be part of a trailer hitch for only god knows what.
Originally I was going to weld a couple mounts on it so I could hang some scrap brake rotors/drums on it for weight, but I forgot before I carried it out of the shop, so like any good project that will never be fixed because rocks worked almost as good and were way less effort at that point.
Honestly it works pretty good. Maybe more weight would be better. I debated painting it, but it's just going to get rubbed off anyway. It did remove about 90% of the weeds with only a few passes, and it took me about 3 hours to build, so I think I'm ahead on that.
To do it over I think I'd use the other beam I had lying around, it had a wider flange, however it's only been aging for a couple years so it's really not ready for project use yet. I probably could have welded a hitch receiver in it too, since that would have been useful, along with mounts for said brake rotor/drum weights. It works well enough I'm sure I'll not bother to make a new one though.
Reactions: 16 users
GrumpyFarmer
4,292
That’s a great material repurpose project. If it works it works. 👍
6,981
Nothing much more rewarding than making something useful out of a "bone pile". Nice work. If you need more weight it would be easy to weld a shaft to the upright and hang some dumbells on it.
5,800
LOVE IT !! great to see 'stuff laying around' get repurposed and used for a good cause ! I used to drag a 6x2 C channel with old tractor chains around here once a month, behind a (hp Sear garden tractor. Did a real good job,place look great for another month. Dang weeds grow fast here...
ejb11235
BX23S, Braber BBR4G 4'BB & LRM5G 5' rake, Redline 48" rock bucket, PFL1242
Jan 20, 2022
486
373
Seattle, WA, USA
To do it over I think I'd use the other beam I had lying around ... however it's only been aging for a couple years so it's really not ready for project use yet.
OMG that thought process seems awfully familiar to me. It's not good enough to actually have a use for something lying around in the shop, but there might be a better use for it. :LOL:
2drx4
B7100
Jul 24, 2023
60
90
PG, BC, Canada
www.4x4north.com
Yeah, I'd rather use up some of the junk that's lying around instead of buying more, it's more rewarding and helps clean the place up. It actually does a decent job of smoothing things out too. Probably wouldn't cut it if things were too bumpy to start with, but for just maintaining a driveway it seems like it should work.
2drx4
B7100
Jul 24, 2023
60
90
PG, BC, Canada
www.4x4north.com
Dumbbells are too pricey for me. Hence I use brake rotors or drums. 😂 I might just weld a piece of leftover pipe onto it for that though, once I have the shop cleared out again in a week or so, it would only take a few minutes.
Yooper
3901 LA525
May 31, 2015
1,663
806
NE Wisconsin
Nothing dubious about it at all! That is well built! You will get the weight thing figured out
Flintknapper
L2350DT
May 3, 2022
1,979
2,507
Deep East Texas
Couple of bags Sackrete, mix and pour into those voids on top....done.
4,088
Love everything about it.
Repurposing things is awesome and I like the ingenuity too.
I would much rather build that, rather than pull weeds!!!!
Lots of very talented people on this board.
Good on you sir! (y) (y) (y)
2drx4
B7100
Jul 24, 2023
60
90
PG, BC, Canada
www.4x4north.com
I had it back in the shop for other reasons, so I kinked up some pipe to mount some old rotors for weight. I had some bike handle rubbers leftover from something else, so I put them on the ends to reduce the risk of impaling myself. The only funny thing about this is I did a big cleanup and threw out a ton of my old rotors, so that's all I had left. 😂
