Setting up WoodMaxx chipper.
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
175
226
NH
Just uncrating WoodMaxx MX 8800. Most robust boxing/palletizing I have ever seen. Of course after unboxing, saw that the 3 pt was facing the wrong way so will need to turn it around with pallet forks to expose approach for the 3 pt. It is bolted to the pallet and am thinking of mounting pressure treated skid plates to bottom of frame once I lift it off the pallet to keep the steel frame off the ground. Seems like a no brainer but am I missing any potential pitfalls in doing this? Wonder if this will mess with PTO linkage height or other issues. My first PTO implement so will need to figure our shaft length,hookup and PTO function. As always, all suggestions appreciated.
2,814
1,530
The chemicals in pressure treated wood might be corrosive, they recommend corrosion-resistant screws. How about a plastic piece?
3,549
2,010
I welded up a steel frame on mine using 2x6 steel tube that allows me to grab the chipper with forks on all four sides. Makes storage easier. The wide base stops the chipper from sinking into the ground while chipping. The added weight also dampens vibration.
Gaspasser
Dec 16, 2023
175
226
NH
Thanks PoTree and Mike. Appreciate the feedback. Hadn't considered the PT wood corrosion issue. That's important for fasteners but I had nor considered contact with the steel frame. Perhaps bolting on a plastic pallet, or instead, strips of plastic flooring/membrane a "gasket" between wood and steel. Thanks guys. Now I just have to figure out cutting PTO shaft to length. Another educational hurdle for this newbie.
4,246
There are a bunch of really good videos on YouTube that show how to shorten a PTO shaft. Watch a few about 5 times, measure twice, cut once (actually cut twice, because you have to cut both ends to shorten it).
Elliott in GA
Mar 10, 2021
744
726
North Georgia
FWIW, I did not need to cut the PTO shaft that came with my WoodMaxx MX 8500G+, but I use a LP Quick Hitch. I simply picked up the chipper with the Quick Hitch, and I raised the chipper to a height where the PTO shaft would be level - PTO stub to PTO stub. This is the shortest point for the PTO shaft in the 3 point arc. I attached the PTO shaft to the chipper, and then I had to extend it several inches to reach the tractor's PTO stub. So, no cutting needed. YMMV
Gaspasser
Dec 16, 2023
175
226
NH
Tha
Thanks NCL. Funny you said that because I've watched multiple videos multiple times today. The written instructions are quite confusing. Basically, I've boiled it down to determining the shortest length at all positions of the 3 pt and then giving myself 3 extra inches shorter for wiggle room. As long as I have better than 1/3 overlap of the shafts, I should be good. Got grinder and cutting wheel ready but just finished chipper assembly this evening so mabye work up the nerve to cut the shaft tomorrow. What could possibly go wrong (yikes). Thanks again for advice.
Gaspasser
Dec 16, 2023
175
226
NH
Thanks Elliot. I use Pat's quick hitch but still cannot make connections. Shaft is too long at shortest compression. So will see tomorrow.
Gaspasser
Dec 16, 2023
175
226
NH
Thanks Mike. Any pics available? Sounds like a great idea.
Merlota
Mar 27, 2024
ga
I did a 4x4 PT base for 7" of lift to keep the PTO almost exactly straight when running. I don't use any quick hitch so the shaft was very short and the angle got steep quickly. Felt more comfortable with it straight when in use.
Gaspasser
Dec 16, 2023
175
226
NH
Finally finished assembly of WoodMaxx chipper. Apparently their employees are happy with their work. See pic #2.
