Long Term Diesel Storage?
lynnmor
B2601-1
May 3, 2021
1,444
1,159
Red Lion
Home heating oil is the same a diesel. I have a 275 gallon tank in the basement vented to the outdoors. I burn wood most of the time and use about 45 gallons of heating oil per year and that gets replaced about every three years since there is a 150 gallon minimum. My shop has a 275 gallon tank that is outdoors and that needs a full tank each year. After many years there has been no issue with the oil.
5,542
From my experience, I have had many machines start up after sitting for over 10 + years no problem
At the end of the day if the tank has proper vent allowing fumes to escape and keeping the moisture out, it will last
I would not recommend putting any kind of chemicals while its in your storage tank
I agree. I had a dozer that has set for YEARS and the fuel smelled like varnish. After a little tinkering the engine fired up and ran fine. Storage life could be a function of where/how and climate the fuel is stored.
4,897
A tank inside is a LOT different than one at side of barn that gets hot, cold ,humdidity,etc.
4,814
All tanks eventually get moisture in them, and how the moisture is dealt with counts. Ask anyone who has had a 275-gallon tank in their cellar for 20 years if they have ever had to deal with a leak at the bottom of the tank. In some states, anyone living near a public water facility (lake or river) must replace their steel tanks with new polypropylene tanks with an outer steel casing. If I were looking for fuel oil storage that is the only type of tank that I would consider. Most steel tanks leak eventually, and that is why homeowners who have underground tanks are encouraged to remove them and replace them with new containment-type tanks.
5,066
I buried a 1,000 underground heating oil tank, and used it for 20 years. Then the county required that I put in an engineered "sniffer well"
They had a Summer kid come around for a few years to use the "sniffer', but that program eventually disappeared.
Natural gas became available, and I switched.
I became concerned that the county was going to eventually require a many $$$ certified tank removal, so I removed the tank, used a Skil saw to cut it up in pieces, and crushed those with my BH.
Took the crushed mess to a construction debris recycling facility, mixed in with a lot of other debris.
Oh,......did I mention,.....when I bought that 1,000 gal. tank,...... I bought a fibreglass tank?
Figured that some day I actually might need to dispose of it!
4,897
re: Most fuel tanks on equipment are located outside like this roller
not relevant.
OP wants to store 150g of fuel in a 300g tank for a year which is waaaaaay different than a roller, that probably gets used every day(M..F ) and refilled often.
