Key switch seems to work properly. I’m thinking fuel shutoff solenoid but the engine runs until it is released to the on position. It did this a few times but then started and ran fine til I shut it off. Now it wont fix itself. Thanks in advance.
Thank you for the input. Turns out the replay that keeps the fuel shutoff open needs a lot of voltage. The battery was low when I picked it up after buying it. Put it on a charger with 60 amps, it stared and ran fine. i did not put anew battery in but will get one tomorrow. Again thank you.
