Hydraulic leak on GR2120 transmission
Low Lander
1980 B6100 4WD, 2005 TG1860 mower and 2020 1025R JD w/FEL & BH, 2016 GR2120
Jul 10, 2022
NE Oklahoma
Mines dripping a little puddle of fluid parked on shop floor. I checked dipstick and none touching. I guess it was leaking out while I was mowing. I started it up, sprayed it with brake cleaner and scrubbed it with a tooth brush. Then dried it with Scott paper shop towels. Nothing obviously pouring out so I replaced the tranny filter with 75 new hours on it and cleaned the strainer screen.
Okay I topped it off with new trans hydraulic fluid. I mowed about 2 hours checking it twice. By the time I got back to the shop it was empty again. Fluid covers everything down both sides and across the bottom casting. I replaced one hose clamp, rerouted two hoses to train them better then added new tie wraps to hold them in place to avoid wear.
Has any GR2120 glide steer owners in here experienced this problem? I’m thinking of adding infrared dye to maybe spot the leak. Any help or suggestions would be appreciated. Thanks, Mike
Low Lander
Jul 10, 2022
NE Oklahoma
Did I not post properly or did just no one reply? 🤷‍♂️
MOOTS
MX6000
Jun 27, 2019
2,189
2,717
Canton, Georgia
Not speaking for everyone, this is more a tractor forum. There are some techs here that may have some ideas where your leak may be coming from. I’ll tag them.
@North Idaho Wolfman @lugbolt @whitetiger There are more, but these are the 3 I know are very knowledgeable over the whole orange line.
  • Dislike
Low Lander
Jul 10, 2022
NE Oklahoma
Hmmm, so orange compacts, lawn mowers, ZTR’s don’t get to participate? For a guy who owns 3 Kubotas seems kind of exclusive. Thanks for the reply. I won’t bother the orange tractor owners again.
  • Sad
MOOTS
MX6000
Jun 27, 2019
2,189
2,717
Canton, Georgia
Not how I meant it. Sure, there are all types of orange here, just seems to me, it is primarily tractors.
TJP440
Gr2120 and B3200
Apr 16, 2017
65
34
Omaha, Ne
Sorry for the delayed response but i don't get a lot of free time. Our GR2120 began loosing fluid and the issue was a poorly placed/routed breather that had fallen and consequently was dispensing hydro fluid. It is located in the LR upper corner. remove the rear cover and it's easy to find. With the cooling fan below it it can spread the fluid everywhere. Good time to clean all the clippings etc. off the housing. Do be aware that overfilling can lead to "burping" when hot.
Manual says the level should be checked with the deck up or down? Can't remember which :(
Filling in the wrong position may cause the issue as well . 🍻
i also covered some hoses that were rubbing on things and zip tied others ;)
9,674
No need to have an attitude.
Posts sometimes just get over looked by the right person.
5,506
2,213
no, you posted in teh right place. A lot of us techs that dealt with GR series mowers despised them (myself included) and generally avoid them at ALL costs including forum suggestions. My best suggestion? Sell it!! :D
could be anything leaking. That transmission is a poor design, not known for longevity. There are many points that can leak. Axle bushings/seals, glide steer lever seals, pto clutch seal, vent, etc
I have worked on more than a few that have "vented' fluid out of them and the only "known" reason was due to the design of the vent itself. Basically the transmission has two halves, front and rear. If you have had one apart you will see what I mean. There is no gasket between them so they used "liquid gasket" (as Kubota calls it....aka silicone). The case assembly has to vent to atmosphere so that hot fluid can expand. The case halves have a channel cut into them which is the vent. The bad part about this design is that there is VERY small space for the sealant to go and it's really, really easy to get a little excess sealant into that channel which will cause the trans to vent fluid. It's nearly impossible not to get sealant in the channel actually. You have to use just the right piece of string in the channel and assemble it normally with sealant, then pull the string out-and hope it comes out, as the channel is not straight-not at all.
If "I" had it in front of me (and thank goodness I don't), I'd clean it all off real good and inspect the source of the fluid leak. HOPEFULLY it's a pto shaft seal or something easy, because if it's venting or if it's a axle seal, you're gonna be doing a total transmission overhaul to fix it, IF it fixes it. I've had a couple that could not be fixed and had to be replaced, and at the time they were $3800, so probably $6000 now based on the constant price increases.
don't fill the trans to the "full" mark. Fill it to the low mark and no more. That helps keep them from venting; although not foolproof. The two lines are not low and full they are full cold and full hot, that info right from an enginerd at kubota.
tbk5
L3710, L3010, ZD1211, RTV900xt, GR2100, lots of 3pt equipment
Sep 24, 2013
184
Central AL
I did not know this. Thank you. I am contemplating redoing the transmission on my GR2100 for the fourth time. My wife calls it my zipper mower because of how quickly I can take it apart. It was fine for a while but has started leaking again. I am off next week. I plan to take the body shell off, clean it up well. fill er' up, and run it to see where the leak is coming from. I had a tough timing getting the PTO in so I am hoping that it the source. I fill it to the top line before mowing and wind up at the bottom line. It is a great little mower when it is not apart in my garage. :rolleyes:
My first leak turned out to be the drain hose from the control valve to the top of the transmission. It had gotten brittle. That was an easy fix. I posted a picture once but can't find it. The WSM shows the location.
EDIT--found the pic. The hose is part 10 in the photo.
I hope it is a simple one for you.
5,506
2,213
if you had the pto clutch out and didn't have the tool to line everything up correctly, there's good possibility that the case was cracked during installation. I've done it, a couple times, and it's pretty easy to do. Leaks every time.
tbk5
Sep 24, 2013
184
Central AL
I did have the tool. Whether I used it properly, we'll see...
First objective to to figure out where the leak is coming from. It may be a winter job. Right now I am using the mower every week. I just check the oil before each use. I add about 4-6 oz every other use. I have the bagger for this machine. It does a very nice job on the bermuda lawn around the house.
William1
BX25D
Jul 28, 2015
1,295
485
Richmond, Virginia
Leaks... Fluid 99.99% of the time utilizes gravity. So a 'fresh leak' starts at the leak and goes down. If left unchecked and perhaps has air blown at it, it can migrate up.
So... A method to find them is top off fluids. Completely clean the area. Run for a little while, sprinkle baby powder in the suspected area and lightly blow off with compressed air. Nothing? Run it longer and repeat.
TJP440
Gr2120 and B3200
Apr 16, 2017
65
34
Omaha, Ne
I wanted to repost again after just completing the 600 Hour service. I had checked the fluid before doing the service and it was at ~ the 1/2 mark. A bit puzzling as I had no signs of leakage just the normal buildup.
I proceeded to do the service and left it t the 1/2 full mark knowing that some hydraulic fluids expand with heat. After the first use. I rechecked the fluid while hot and it was at ~ the 3/4 mark so it topped it off. I should mention there were no leaks.
The second use resulted in fluid being burped and of course making quite a mess.
So I cleaned it again and lowered the level to the 1/2 mark when cold.
2 more uses no leaks, AWESOME. But of course I had to top it off again as I had not read about leaving it lower than full. Instant mess AGAIN 🤬
In my original post I had not mentioned that my unit had previously started puking fluid. Not having the time to deal with it I called the dealer and did a trade on a new unit. I won't go into the entire story but will just say I wound up with my original unit back. I suspect that is why it was at the 1/2 mark when checked 🤔. I did relocate the vent to the highest point I could and all was well until did the service and unknowingly filled it to the full mark. I have to admit I had employees doing the servicing for me prior to the initial incident and its possible they were not filling it to the full mark. I'm not 100% sure where the VENT is supposed to be located but the length of hose does not leave a lot of choices. I believe it came loose and caused the first issue.
I plan on lengthening the hose to allow raising the vent as high as possible. I do believe/ hope this is the root cause at this time.
I am also using Super UDT 2 which may have different expansion rate than it's predecessor.
I also have a B3200 which has been a reasonably good unit but not as good as the 2750 or 3030 I previously owned.
Overall I am quite unhappy with Kubota. I have owned many over the years and it seems as though their quality is definitely slipping similar to Detroit's footsteps circa late 70's early 80's. I'll post on a few other GR 2102 shortcomings in separate posts 🍻
5,506
2,213
it's a GR series
Kubota has had transmission issues with all of the GR series since the day they came out, and they still haven't gotten them fixed. The newer they are the longer they'll go before the transmissions start giving troubles, but eventually that is their nemesis--the transmission. The rest of the mower is pretty good.
could have been a wonderful mower, but the transmission design ruins it.
It's not so much a reflection on Kubota as a whole, Kubota builds a good product. Except the GR series mowers and the B3350 and ZD1511. And RTV-XG850. Every manufacturer has a couple black eyes in their lineup.
TJP440
Gr2120 and B3200
Apr 16, 2017
65
34
Omaha, Ne
it's a GR series
I know the early units had a lot of issues, mine is a 2017, do you feel the trans issues were corrected by then?
Have there been further improvements on the newer models?
Asking because I am part way through the 600 hour maintenance and have found several other issues somewhat minor but still poorly designed.
iam contemplating buying another or a deere OMG 🤫
tbk5
Sep 24, 2013
184
Central AL
it's a GR series
I agree--great cutter and yes, every manufacturer in every industry has a few black eyes. I think what is important is how they deal with it. In my opinion, Kubota left buyers of the GR series high and dry. The GRs are Kubota and the company is still selling them despite the problems. I have five Kubota machines lined up in my driveway. The UPS guy thinks I am a dealer. My experience with my GR, however, has unfortunately turned me off the brand.
5,506
2,213
Kubota has addressed some of the issues, but has failed to address all of them.
  • Sad
TJP440
Gr2120 and B3200
Apr 16, 2017
65
34
Omaha, Ne
Too late at this point as I bought a new one. the deere was just too $$$. The previous unit lasted 8+ years. The fluids were changed by employees but other parts of the servicing were not done as I came to find out. So if I get another 8 years I'll be getting close to not giving a :poop: 🍻
