I have bought one and it does not work.Can't read model and serial number on boom.How do i find the right kit?
There is only 2 kits so if the first one you got does not work, get the second kit.I have bought one and it does not work.Can't read model and serial number on boom.How do i find the right kit?
My tractor is down now because of seals and o rings,so now goes another week till it gets fixed but thats ok.You are sure of the fact that there are only 2 kits?There is only 2 kits so if the first one you got does not work, get the second kit.
There was only 2 variations of cylinders used, so there should be only 2 variables to the seals.My tractor is down now because of seals and o rings,so now goes another week till it gets fixed but thats ok.You are sure of the fact that there are only 2 kits?
The one i bought that don't work isThere was only 2 variations of cylinders used, so there should be only 2 variables to the seals.
I have watched 5 videos and none of the pistons looked like mineThe one i bought that don't work is
ATQUALOD 7J266-63400 Boom & Bucket Cylinder Seal Kit Compatible with Kubota Front Loader LA463 (S/N Before 24767), LA513 (S/N Before 30219) And Kubota Tractor(s) (set of 4)
I can’t really help you, but I can make a couple observations for what that’s worth.I have watched 5 videos and none of the pistons looked like mine
I bought tractor used.I ended up taking hard parts to a repair shop and for 38 bucks he put mic to them and went to the book,then to abinet and installed the right o rings and seals.Job done...Thanks to allI can’t really help you, but I can make a couple observations for what that’s worth.
I think it was assumed that you bought the seal kit from Kubota. Aftermarket is always a question mark. Perhaps you would want to contact the seller and see what they say.
Second is are you sure that the cylinders on the loader are original? I would bet they are. Did you buy the tractor new or used? If bought new, then you know the answer to that question.
