How to remove power take off pulley on front crankshaft Kubota B7100?
r.wagner75
Kubota B7100 Diesl HST
Feb 16, 2023
9
Smuggler’s Den, Belize
Anyone know how to remove the power take off pulley from the crankshaft on a Kubota B7100? There is no way of putting a puller on this thing without damaging the aluminum cover. Does this thing split in half somehow?
1,415
See post #31 in this thread for information that might help
I have no idea so won’t make any suggestions but will wish you good luck
5,235
1,018
Most owners of these machines are looking for ways to connect stuff to the front of the crankshaft like a higher capacity hydraulic pump.
Why do you want this off/
6,387
The inside of the adapter is splined to the crank and it's packed with dirt, start by cleaning that out with water and air.
Then it should just slide off the crank and then there will be a nut behind it to remove the main pulley.
r.wagner75
Feb 16, 2023
9
I have end play on the main seal and crank shaft at the rear. Im trying to tear the engine down
r.wagner75
Feb 16, 2023
9
Thanks for the response. I did manage to work it free. it had a lots of rust and dirt holding it together.
