BH92 creaking noise when moving the boom left to right not in and out
Scorp
L4802, BH92
May 9, 2024
Was on my L4802 (18.2 hours on it) digging some rocks out of the yard, when the BH92 started making a creaking noise when i move it left to right, doesn't do it when booming out or in. It's hard o explain what it sounds like, but the best I can think of is if you shut a old door slowly. I should mention that as well it makes this creaking noise when you move the boom slowly. I've greased everything till grease is coming out of the connections, and it still is making this noise. I bought the tractor May 25th and have used the backhoe around 8 hours total.
Can anyone please help a newbie out here, thank you.
Donystoy
Dec 10, 2013
663
300
Binbrook, Ontario
I would look for loose bolts on the subframe as well as cracked welds. Try to narrow down where the noise is coming from. I assume this is new equipment.
5,163
Seems as though several grease zerks may have been missed?
3,539
I would first grab the manual and go over and highlight each zerk to be sure you haven't missed one.
I would also move the boom "full left" then grease, then move it "full right" and grease again or some combination of angles. Maybe there is a "dry spot".
After that, I would probably use a "mechanics stethoscope" and have someone move it while you put the "scope" on various locations to pin point the source of the "creaking". (in a pinch, I have also put the handle of a long screwdriver in my ear and used the tip to locate noises)
lynnmor
B2601-1
May 3, 2021
1,565
1,319
Red Lion
Kubota is good at painting grease fittings shut or not tightening them, so be sure that grease is actually going thru and not just forming a pile next to the fitting. Black moly grease is recommended for a backhoe.
Scorp
L4802, BH92
May 9, 2024
Thanks, I didn't check for paint over, and thank for the recommendation about the grease.
Scorp
L4802, BH92
May 9, 2024
Is that really a thing with the screwdriver or are you trying to make me look bad :), I know I said I was a newbie.
Scorp
L4802, BH92
May 9, 2024
Thanks for the suggestion, I did look and didn't notice anything.
6,826
No, the screwdriver trick is real. Lots of folks do that for many applications.
Given it's the swing of the backhoe, one would have to be very cautious.
Don't want anyone to get their head in a "bind."
3,539
It's a thing for sure.
I have a 30 inch'ish screwdriver that I use when I can't find my stethoscope.
But I can see why you would be cautious.....just don't fall for the old "Go to the parts store and get me a cable stretcher." line, like my daughter did.... 😂 😂 😂
pokey1416
Jun 24, 2020
567
843
SW Michigan
Mine did that new too, it was the pivot wasn’t getting enough grease. Do like RWS said and it should take it. Next I’d try one of those zerk cleaners with WD40. I’ve had good luck clearing zerks, just tap on the end though, if you clobber it you may create trouble.
Scorp
L4802, BH92
May 9, 2024
LOL...ok, I'm gonna get me a long screwdriver and try this out. Thanks for the advice its' much appreciated
Scorp
L4802, BH92
May 9, 2024
Thanks, I'll try that. Also good to know that you had a similar or same issue. Local dealer had me talk to a tech that said it was more than likely growing pains and not to worry about it and just use it, he also mentioned that it is under warranty, so i guess "use it till it breaks then fight to get it fixed" is the mantra. I thought they would have at least want to come out and check it.
pokey1416
Jun 24, 2020
567
843
SW Michigan
Yep I videotaped the motion and sound and emailed to dealer. I figured that way it was on record.
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
I have a set of clip on microphones that connect to a head set. I use for hard to pinpoint noises on automotive chassis etc.
Maybe one of your local parts stores has something like that for rent????
MBEE
L4060
Jun 16, 2025
Washington
Thank you for the information. I just started hearing that "creaking" noise on my BH92 Backhoe which I only have 26 hrs on the L4060 Tractor/Backhoe. Mine is creaking going from right to left and mainly hard left. Checking grease zerks again today and will likely record sound and talk with dealer to cover my bases.
Grandad4
Apr 5, 2016
382
125
Greensboro, NC
There are a couple of other places besides moving parts with grease zerks that could cause a creaky backhoe, potentially serious ones at that.
First are the mounting points where the backhoe attaches to the subframe. If the backhoe was not well secured to the subframe, it might be shifting enough to make noise. Don't know the BH92 setup but my old 4560 backhoe was secured down with wedge bolts that could creak if they weren't tightened enough.
Second, is the subframe itself, typically bolted to the tractor. If something there is loose, again some kind of groaning or creaking would be a warning.
Both of these could be dangerous, obviously. Since you have new equipment, I would want the dealer that installed the hoe to make sure everything was still mounted securely after a few hours of use.
3,539
One other thought.
If you can duplicate the noise fairly consistently, it might be rather easy to pinpoint it using an "automotive stethoscope".
They are pretty cheap, and have come in handy for me personally.
In a pinch you can also use a long screwdriver by holding the handle to your ear, and then touching it to "suspect areas". (Not a joke, it actually works rather well)
You might need someone else to work the machine while you "probe around".
Good luck 🍻
EDIT; As you were......I see that I already suggested this.........NEED MORE COFFEE!!!!! :ROFLMAO:
MBEE
L4060
Jun 16, 2025
Washington
One other thought.
Good luck 🍻
Thank you. I am waiting a call back from my dealer so will see what their service rep says. I think I pinpointed the sound coming from the "swing cylinders". Appreciate the help!
