More easily adjusting lift rod on 3 point?
Ricklesss
L3901
Aug 5, 2020
37
14
Dexter Oregon
Hope this is the correct subforum.
I see very little on this subject, so here goes…
I really dislike adjusting that right side turn buckle on the lifting rod of my 3 point. Especially for frequent adjustment.
I keep it greased, but find there isn’t really enough to grab a hole of, on those little 2” round rod nubbins.
I searched the Orange Tractor Talks forum, but don’t see any mention of a ratchet mechanism to replace the turnbuckle.
Isn‘t that a thing?
Someday maybe I will have a hydraulic top/tilt, but in the meantime thinking if welding a ratchet style chain binder to the middle of my lifting rod might be the way to go.
I did just see a new post on this forum by a member, for a new tool available to twist that turn buckle, and might go that route.
Rick in Oregon
SDT
multiple and various
Apr 15, 2018
3,250
1,041
SE, IN
An optional ratcheting mechanism is available for the B/LX series.
Doubt you will find one for the L series.
4,227
I have hydraulic top and side links now but for about the first year I had the stock turnbuckles with the little nubs. About 5 minutes into adjusting my boxblade, I took a detour to the scrap metal pile and found a piece of pipe that fit the nubs on the toplink and another that fit the nubs on the side link. Cut them to a usable length and figured I’d do something better when I had time. But they worked so well I didn’t do anything more sophisticated until I replaced them with hydraulics.
Ricklesss
L3901
Aug 5, 2020
37
14
Dexter Oregon
Did you use a length of pipe with an approximate 3/8” I.d. to slip over a nub?
or somehow make it fancy to somehow fit both nubs?
6,339
Isn‘t that a thing?
Rick in Oregon
Leveling box
4,227
Nothing fancy. Two different pieces of pipe. One to fit the toplink. Another for the sidelink.
BTW, the leveling box posted by NIW are really nice. Had one on our old Ford. Could reach back from the seat and adjust it with one hand.
Ricklesss
L3901
Aug 5, 2020
37
14
Dexter Oregon
Thank you both for those last two posts. I didn‘t notice either one until this a.m. and appreciate it.
I know nothing about those leveling boxes, but will be sure to check them out.
The way I‘m adjusting it now, with those two “nubbins” is terrible and I really want to change it.
Thanks!
