Need advice on plumbing this la210 off a bx23 into the hydraulic system of my b7100hst. As for mounting I'm going to make adapter brackets to the b7100hst fel frame and add forward strut brackets. Thanks
You also MUST make a subframe to go back to the back axle too or you will break it in half.
Send @torch a message and see if he has any adapter blocks available to send out.
Then you will just have to add a tank return and you'll be good to go.
FYI: The loader will be slow, as the on board pump on the B7100 HST is much less GPM than the BX23.
Like @North Idaho Wolfman said it will be very slow. But you can replace your hydraulic pump with one from a b8200 (there are 2 types and direct drive right hand and a gear drive left hand. You need the direct drive right hand) to increase your gpm from 3gpm to around 6gpm to help with that. It is a little tricky getting on there but not terrible
CURRENTLY SOLD OUT. Making more is a winter project. I will remove this line when I have made more. These are obsolete and no longer available. I have recently been contacted by a member asking if I will make him one of these after reading how I made mine. I know this comes up from time to time...
