First season using my new-to-me B7500. Most of my tractor use is spring mowing of tall grass. My ground is hilly and uneven, so I usually need to adjust the cutter height a lot for bumps and berms, etc. Without position control of the hitch, it's a fiddly operation to get the cutter height set, and impossible to raise it for an obstacle and return it quickly when needed. For me the result is quite a bit of unintended landscaping.
Also,
when the hitch control lever is in the neutral position, it cannot float upward. Do I need to put a floating attachment in the top link connection like some brush hogs have?
Any suggestions or tips appreciated. I also use a landscape rake for "haying" and maintaining a gravel driveway. The Down lever floats the 3 point, and that works well with the rake.
Also,
