B2601. 54" or 60" loader?
Tundrabuggy
B2601-1 TLB BX25 (sold)
May 25, 2024
U.P. of Michigan
Hello. New member here. Just sold my BX25. I am about to pull the trigger on a B2601. I am on the fence about the bucket size that I want. The tractor will be mostly used for moving dirt, sand, and some gravel. I will also use it to lift firewood rounds up to a wood splitter. One dealer states that all they sell on the B2601 is the 60". Another dealer says to go with the 54". I am leaning toward the 54". 60" is stated on Kubota build site as a "Light Material bucket.
Also, my BX25 had R4's. They were great in the woods, never punctured one. Anyone have any issues with the R14's?
Thank you.
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
363
144
St. Louis, mo.
For what it’s worth I have the 54” on my b2601 and with the bxexpanded tooth bar it is capable of digging jobs or moving gravel, dirt, etc. To me it’s a better fit for b2601 compared to the 60” bucket
7,333
I don’t have a B2601.
I don’t think you’d be disappointed with either 54 or 60.
I think the light material buckets are of similar construction, just a little bit bigger, and thus may be a little heavier. Detracts from the lifting ability of the loader a little.
Looks like you’re using the loader more for heavy stuff like dirt, stone and wood blocks.
You’re not moving mulch around which is much lighter
I agree with @Steve67 that a 54” would be fine and definitely agree that a Piranha Toothbar is a must-have.
I’ve had a PTB from BXPanded since I got my BX years ago and love it.
GrumpyFarmer
5,212
Good day.
I agree with above advice.👍
Only other thing I would add is that I would want the narrowest bucket that covers the tracks. 🥃
lynnmor
B2601-1
May 3, 2021
1,804
1,609
Red Lion
I have the 54" on a B2601, never needed or wanted a larger one, you can always take another pass if need be. Get a heavy cutting bar, either straight or a Piranha type depending on usage as they will prevent the bucket from developing a smile.
PaulL
B2601, MX5200.
Jul 17, 2017
2,798
1,791
NZ
I have 54". I probably would have purchased the 60" if it were available, but I don't feel that I've missed it.
Light materials I don't think refers to the construction, it refers to the fact that if you filled the 60" bucket with heavy materials the machine would have trouble lifting it.
Of course, my loader technique isn't that flash, so my bucket isn't full all the way to the top all that often.
I don't think you can go wrong either way. I'd buy the bucket that's in stock at the dealer you want to buy from.
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
238
88
S.E. TN
A 60” bucket full of whatever is gonna be a lot of weight off the front of that tractor. I have a 54 and have had the rear off the ground in the rough With a bucket full. I’m happy with the 54 on the 2601.
Tundrabuggy
May 25, 2024
U.P. of Michigan
I did have the Piranha tooth bar on the BX25. I liked it alot. I plan on getting one for the new tractor also. I may get the 60" bucket and try it out. If I don't like it, I can always buy a 54" and use to 60" for snow removal.
saskydude
B2601, FEL, BH70, HLA 1500, K54-22-06. PFL-1242
Nov 23, 2020
Saskatchewan, Canada
I have a 60" because that's what was on it. They said they sold all the 2601's that way. If I'm scooping something heavy I just get A 3/4 bucket and away I go. Less spilling on a bumpy road is a bonus and the build quality is perfectly fine. I ordered the R14's but they took months to get so i used the R4's for a winter. The R14's are far superior in snow removal, I don't spin the rears as much compared to the R4's. R4's will wear better in the long term, though.
5,164
I would recommend the 60" bucket, and it will be overall a better fit, even if you can't fill it with heavy loads. Ask what the weight difference is between the 60" and the 54" bucket. Read previous comments below.
and for opinions outside of OTT........
It really comes down to opinions, and everyone has one. :)
Trev450r
B2601, Z231KH, Woodland Mills WC68
Jun 17, 2021
25
27
I have a B2601, and it has the 60" bucket. I wouldn't go any smaller. I've moved lots of dirt, sand, gravel, wood chips, and snow. 20221104_155549.jpg
Tundrabuggy
May 25, 2024
U.P. of Michigan
Thank you DustyRusty.
I did a search before posing the question, but I did not use "FEL" ,I used loader instead. I knew this question has been asked lots of times,
Tundrabuggy
May 25, 2024
U.P. of Michigan
I will have ballast, there will be a backhoe on it also. I can attest that on the BX25, even with the backhoe on it, a full bucket is a lot of weight up front.
JimmyJazz
1,273
805
Pittsburgh, Pa
Thank you.
I also have the B2601 with the 54 inch bucket and Piranha tooth bar. I feel the 54 inch bucket is plenty big enough given the loaders lifting capacity. I also added some bolted on shackles to the top of the bucket. I like to use straps to aid in lifting ,securing , pulling logs ,shrubs ,fire pits ....... you get the idea. Others like chains. Many here have commented as to what kind and where to get them. I bought mine off of either Amazon or eBay. Nice to have. I opted for turf tires with the rears loaded as I do plenty of mowing. You will love the B2601 . I have beaten the hell out of mine on my 2 1/2 acre suburban lot. Its important to remember that these little tractors can kill you so be careful. I have nearly shit my pants on several occasions. Be safe and good luck!
Velma
B2301, FDR1660, RB1560, SGC0554, Pats QH, CMP Dethatcher
May 12, 2022
96
59
MI
Depends on what is in the bucket...60" of dirt/rocks maybe too much for the B. Sometimes 54" is too much.
PA452
B2650
55
Western PA
I'd go with the 60".
I debated the same option when buying my B2650. Now I can't imagine having a smaller bucket. As said, they call it a "light material" bucket just because if you really filled the thing to the brim with a heavy material it might be a little heavy for your machine. If you're going to have a backhoe though, that's excellent ballast. Can't speak for the B2601, but with my machine the loader simply won't pick up a heavy load before the rear wheels are even close to coming off the ground.
Tundrabuggy
May 25, 2024
U.P. of Michigan
Thank you all for the posts. I went with the 60". It looks like my trails out at the camp will be just a bit wider. That is okay, I will be able to drive the side by side down them.
I won't have the tractor for a while, the dealer has to order the backhoe.
PaulL
B2601, MX5200.
Jul 17, 2017
2,798
1,791
NZ
You can get the tractor, then take it back to fit the backhoe. If that was something you needed.
5,607
Pick up a tooth bar, while the 2601 works well a tooth bar will help a whole bunch
